  • Replies 6k
Posted Images
will, it need to be a very high pressure compressor that is able to pump the paint to a fine mist. correct me if im wrong sam.
half right duc, any air compressor should be able to turn the paint into a mist, its jsut the compressor will need to have enough puff to do a whole car. with my old compressor (2.0HP) i had to stop spraying 4 times (painting a bonnet) to let it build up more pressure.
yeah, but it will look awesome when it's finished - and if you took it to a crash repairer it would cost you $2k+ for an inferior quality job.
Yeah, Will isn't too much of a drinker these days, so he is normally happy to be nominated driver!
hey Sam - I am not going to do it soon, but assuming my R34 4 door's paint was in v.good condition, and seeing that it's black already - would it be possible to do a light rub down and do some minor pin dent/scratch repairs, then do a couple of coats of midnight purple over the top? Or would it need to be rubbed right back anyhow like for a complete respray? And/or, are there any other options to freshen up paint to brand new, like adding a couple of coats of clear or something?
Also, a few years ago I saw a car in Adelaide that was painted dark purple, then the clear coat had a harlequin type sprinkle actually in the clear coat. Is that easy to do over an existing colour?
Ill have a look at the paint on your R34 for you when it gets here, chances are a buff & polish will bring up the paint like new.
Yep, its possible to do that
Ive noticed that nissans solid black are done in clear over base, so that would be an option, my only problem with doing this is although the paint will be nice and glossy any minor dents will show up even more
The harlequin itself is actually a transparent layer put down over a black base. seeing as you car is black already, that would act as a base. so steps would be - light sanding/scouring of existing paint, 2 coats of harlequin layer, 2 coats of clear. I would definately recommend that all minor dents are repaired in this situation, the smallest of panel imperfections will ruin the look of a harlequin job.
Hope that helps you out a bit, will give you a few options to think about anyway.
Sam
Use the compressor with a sander to help with the prep work. (anything beats dooing it all by block)
Definately, its way quicker to use an orbital hand sander. the only down side to this is the panels will look all rippley when you look at them on an angle. Using a block or a file with the correct method will give that nice straight look to a panel :thumbsup:
Sam, I know it is a hard question, but can you ballpark me the last option - fix say 6 small pin dents/scratches, lightly sand back whole car, touch up repair work black (as a base), then 2 coats of harlequin, 2 coats of clear? Just roughly, assuming I help you sand and its a private job .... also could you sort of ballpark quote it as an official job through your work (including GST) - as it's a work car I get the tax benefit that way :) .... I won't hold you to it - just wanna know roughly. This is all pie in the sky stuff ... but it's nice to dream :thumbsup:
yeah, thats a bit of a tricky question. i'm not totally up to speed with the way pricing is done, i just put the paint on the cars :). I know that there was a 180SX done by a shop here in SA in harlequin, and all up the price was about $15K. With my own pricing, i havent really got anything solid. My main problem is access to a spray booth. My boss is reluctant to let me even do my own stuff in his booth, he fears that it looses him business. I've tried painting 2K in the shed a few times, and it doesnt work too well, all sorts of dirt, rubbish, bugs land in the paint. But yeah, have a think about it and let me know what you wanna do.
    • Or the brand new throwout may be unhappy...
    • Thanks for the linkie. Certainly always a great deal of help when people post comparisons like these, but I think for now I'll stay away from any semi slicks. I did go ahead and order the sportcontact 7. My buddy has them on his modified A4 and he keeps saying how good they are. For my intended purposes these will probably work real well. I'll report on them once I had the chance to try them out
    • Talk about noisy. Even when I still had the Tomei under the car I could distinctly hear the tires rolling. And I doubt I ever will need maximum grip like on a track. My GTR will maybe never even see the 600hp mark and I need to get used to the car quite a bit before challenging the limits of its handling. For the next winter storage I think I will get a set of these rubber drive-on thingies that have a tire shaped base. Those supposedly really help prevent flat spots.
    • Well our climate is definitely way less hot overall and the weather can be quite picky at times. I just know that during normal road use or even spirited drives there is no way I'd be able to consistently stay in the operating temperature, and constantly changing the tire pressure would also be a royal pain.
    • Input shaft bearing. They all do it. There is always rollover noise in Nissan boxes - particularly the big box. Don't worry about it unless it gets really growly.
