  • Replies 6k
Posted Images
The easiest and cheepest way was to get it fitted by a workshop (I used Morpowa) because GCG offered a discount if a workshop fit it. The discount payed for the installation and tune.
so it was as simple as, drop the car at Morpowa and they do all the rest?
as your likely to get a new/reconditioned turbo sam, do you have the necessary support mods yet or are they coming?
Im organising a power fc too, injectors should be fine at the boost levels i'll use, im pretty sure ive got an upgraded fuel pump too, but i need to check that for sure :)
i know of one workshop that charged my friend $900 for a turbo install. Is this a resonable price - you dont have to state how much you paid guy just your opinion and other ppls opinion in general.
That sounds a bit expensive. The job is easy and quick enough on an R33. I paid less than that and the job included shipping, new coolant and oil, and time on the dyno to reprogram my PFC.
I guess if it wasnt an R33 then that may take a bit longer.
Yes.
Took nearly 2 weeks (but we did it on the 2nd of January and shipping was a bit slow due to the x-mass new-year holliday rush. I think its about 1hr to remove turbo, 1 hour to install then dyno time.
i think it was a HKS GT2530 on R33, right duc? they require some mods before they fit up
It would be wise to install injectors aswell.
I have a rising rate reg, and bigger fuel pump but I am limited to 14psi boost because my injectors are already at 90%. With injectors I shoud get over 250rwkw.
shouldn't be anywhere near that expensive unless custom work has to be done. Both times my manifold had been removed it only cost $400 (not quite as big job as fitting a turbo, but damn close).
Unfortunately it was a 33. im sure replacing the turbo was a quite straight forward process even with some fabrication for the oil and water lines if required. The labour did not include any form of tuning. I personally believed he was ripped off.
yeah it was sam, you know the guy im talking bout. I feel sorry for him. Damn workshops prey on those who dont know any better.
Hey guys
           After reading all of this... Do you reckon I need more stuff for my car. e.g. upgrade fuel pump,etc.. I've got the power fc, avcr, frontmount, ..
what next? Or will it be ok?
Cheers
Iceduck:)
Have you got all that gear installed yet duck?
Thats weak, hey. Just make sure we never take any business there. Yeah, for sure they ripped him off, they probably made about $450 an hour out of that job.
there are certain aspects that they are good at what they do but it just seems that if they can take advatage of you they will.
They do anything to make an extra dollar. Can you PM me the name of the place? i forgot already.
definately agree. aftermarket injectors i.e 550cc variants wouldbe a good investment. I believe rising rate regulators are just a band aid. AI'd rather my duty cycle to be lower, more opportunity to get the most out of your turbs.
Yeah, injectors are on my list. right after i save a bit more money, these mods are a big drain on the bank account
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
