  • Replies 6k
Posted Images
when i started as a painter i thought the sanding would drive me crazy. now im that used to it, its just like any other job.
So hows it looking? no shinny areas? did you smooth out the bitten-up areas in the guards?
Cillham - our clan name is |NaP| = Not a Problem ..... we are quite shit, but have fun :)
Sam - don't get confused by the PC geek-talk - here are translations:
- clan: a group of prople (normally friends) who play the same game, and so form a clan (=gang), and you fight other clans in online or network wars/battles.
- CS:S = CounterStrike : Source - first person shooter game (you run around a virtual world shooting your enemies).
- Valhalla = a large gathering of PC geeks with their computers to play games and share files, whilst hooked up to a large network (up to 500 people in one room, normally a gymnasium). Valhalla is held most months at the St. Clairs Recreation Centre, Woodville (I think they are still held there).
warez: downloaded software or patches/cracks (normally illegal and often user cracked so to online version checkers appear to be real/registered/paid for versions)
pron = PORN :)
pron = PORN :)
ditto. basically a enormous porn sharing operation with the ocassional gaming.
pron = PORN :)
cool, makes sense :). i got the pc network gaming idea, just some of the words were :confused: lol
btw the paint underneath is unbelievable. So many layers, im shocked.
It i do indeed screw it up some how, im just going to get overfenders/wide front aftermarket guards.
yeah the shrink-back/bite-up is due to the million layers of paint underneath. good idea, it might actually be easier to get a pair of vented/wide S13 fenders for it.
that what i was thinking. If i do screw it up then i will have to paint it anyways. So might as well try my skills on the ones on their atm since i bought a shyt load of sandpaper already anyways.
yep more practice is better. have you ever spray painted before?
    • Also build this EH ute with 370z motor and gearbox with a couple of turbos just for fun.
    • Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
    • Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
    • Ok. And Nistune? I read (here too) mainly on Stagea threads that it can by "turn off" with Nistune. But they say they still had the sensor plug in. Next week iam going to the Nistune(and other ECUs) tuner so i can finally make it work. I drove the car home and apart from the cut it drove great. No misfire no smoke no hesitation or rough start...so hoping it is this sensor that is missing
    • I just stack 2 pieces of 200x50 timber on top of each other. Total length about 900mm, with the top one being a little shorter and both having a 45° angle cut on them to make the front edge a bit of a ramp. Put these in front of each front wheel, drive up on them, throw the trolley jack under. Takes 1 minute. Scissor jacks can eat a bowl of dicks. I never use on under my car unless desperate.
