  • Replies 6k
Posted Images
Looking at some of those bull’s eyes it may indicate you need a bit of bodywork or at least a high fill primer.
Did you say you are doing it all by hand?
It can be hard not to get rub marks in the car if you are doing it all by hand, can you at least get a block, or better still an oscillating orbital sander (air tool) to do the majority of the work. You will need to finish it off by hand, but to do the whole lot by hand is a big job.
PS any little imperfection will look 10 times worse with a coat of paint on it. Before you paint it get someone with a good eye to go over it and highlight the bits that need more work.
The first time I painted a car my preparation wasn’t good enough (after a week of work) and the car looked almost as bad with the new coat of paint on it.
hey guy,
thanks for the advice. yeah the bull's eye are obviously dents in the fenders. im using a block and all by hand. Its a big job but i dont have the necessary orbitor equipment so im just going to have to do without it. Im ust concentrating on the sanding atm and then will fill up the dents prior to applying the primer. I aint rushing it so should hopefully be ok.
:werd:
Heya Sleeper, do you have some spare time in the next month to come down to morepower and get my turbo high flowed? Would be good to show them that I want the same service you recieved for the same price etc.
no problem. :Pimp2:
I have a week of from the 9th to the 17th :uh-huh:
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
