  • Replies 6k
Posted Images
looks alright, im not keen on that front grille though. needs to be a bit lower & a different front bar & skirts. i didnt like the 05 one either until i saw a brand new one in the flesh, i got to take it for a bit of a drive too :D
hehe, its just sitting on my bedroom floor at the moment. even when i get my car back i wont be able to do anything with it, cos i'll have to save for the tuning work.
Hi
The PFC comes with a conservative tune preset, so you can plug it in and drive around before you get it tuned. It will drive better than the standard computer, and will be a lot better when you get it properly tuned later on.
I did this to my skyline and had no problems.
Hi
ok cool, ill give that a go. from what i was reading the base map isnt that good, but as long as its better than the stock one, it should be ok :D
Keep an eye on the knock reading and you will be fine.
If you find it knocks at highrpm pull 2 degree's out of the load points wot uses.
I have known a one person that had the stock base map knock due to too much ignition timing. It does run super rich so going lean is nothing to worry about. :D
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
