  • Replies 6k
Posted Images
was browsing the net (s2ki.com forums) for a friends who's interested in a turbo kit for his s2k and came across this. turbo kit supplied by lovefab
v-tec and turbo :O
price? messly $7k USD cheap considering a Vortech S/C goes for $5k AUD installed + tuned (i think)
Edited by Nozila
Imagine revving that thing to limits like V-Tek should. Damn! It really is a damn shame Honda make a shiat load of FWD's.........Way to keep the yanks happy Honda!
i drove a honda prelude around at work today, i love how the 4WS works on those things!!!
thought id share my current problem with everyone, if you had any ideas to help me out would be appreciated. copy pasted below:
Well, I've had my car off the road for 2 weeks now, basically all of which have been spent at my tuner's shop. The problem:
Start her up and will immediatley run very rough, rpm jumping up and down, missing etc. Leave for about 5 minutes and it will idle smoothly instantaneously, or take for a drive and about 5-10 minutes of driving it will act more normal in terms of idle. BUT then it doesnt have any power under load. It becomes flat, you can hear the turbo spool and a rush of air, but goes no where.
What has been done:
He has replaced all engine sensors, AFM, CAS had it on the dyno. Fuel pump, lins, filter all checked as well and cleaned. It is running lean... very lean, so lean the engine doesnt have enough fuel to operate properly, this is occuring on all cylinders.
Higher temperatures seem to make it better, the longer you run the car for the better it gets, but never close to perfect. He had determind that the problem has to lie either with the ECU, or the wiring into it. He is supremely confident that an after market computer will fix this problem. I have access to R32 ECU and loom, and hence this should also fix the problem, once wired up correctly. I need second, third etc opinions though before i go ahead and spend money, hence this post.
I have just recently had the entire intake side off, inlet butterflies remove and sealed up good and propper. exhuast manifold has been ripped off, studs replaced and put back on with the addition of an r33 turbo. Amoutn other things and a full service. Was running fine until about 4-5 days after, then it got progressivly to ths state. It did this before i had this work done, but on a VERY small level, and 10 minutes of driving would see if going perfectly.
hey stevo! there are no boost leaks or anything?
your problem sounds very similar to one of the guys at work who has a VL turbo. had the exact same symptoms and all, weird idle & no power under boost, the boost guage read 9psi and absolutely no extra power, it was the same as driving an NA one.
It tuned out all of the injectors were blocked up with crap & one injector was faulty. injectors were cleaned out/replaced and it ran good again.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
