  • Replies 6k
Posted Images
went on a mini cruise last night with 3 other GTRs, 2 WRXs, and a RX7 S6 to Lobethal and back. Had issues with losing cars in traffic though. Engine was hot and brakes not as reponsive on way home but it sure was fun!
not sure about that one.
i always put BP in my car, execept i ran out last night & the BP was closed so i had to fill up with shell, starting off for the first 5 minutes i took it easy then i went up to about 4500RPM in third and got a knock reading of 75 on the PFC!!! im gonna wait till this tank runs out & im never going to put shell fuel in there again
Sam, Shell don't sell 98 octane fuel in SA, so if your car was tuned using BP Ultimate 98, putting Shell Premium (95 RON) is definitely NOT a good idea with an ECU with no knock control.
To be honest mate, I'd drain it and refill - it might be $60 worth of juice, but how much was that rebuild again? A LOT more.
Oooo, i havent been on a good run for ages! nice weather at night now for it, can actually get out the car and chat without getting drenched.
Also, I'm going for the Microtech to solve my problems, so car should be back at christmas time :(
hope all goes well for ya steve :D
thanks for that info will, i didnt know the shell was only 95RON.
i didnt put much of the shell fuel in there, just enough to get me by. so today i filled it up the rest of the way with BP and its running all good now.
from what ive read the knock reading of 75 isnt too serious, but ive learnt a lesson there.
with that first 4000RPM right before the boost really kicks in, the computer over-richens the air-fuel ratio, not sure why, but thats why it goes all flat. i noticed my car used to back-fire a lot around those RPM, but now it rarely ever backfires
i was originally going to, but i ended up getting it fitted & tuned all in one. i also needed a bosch fuel pump, cos the stock one was running out of puff. i got boostworx do do mine, they did a top job. but i also heard good things about graham west too.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
