  • Replies 6k
Posted Images
went on a mini cruise last night with 3 other GTRs, 2 WRXs, and a RX7 S6 to Lobethal and back. Had issues with losing cars in traffic though. Engine was hot and brakes not as reponsive on way home but it sure was fun!
not sure about that one.
i always put BP in my car, execept i ran out last night & the BP was closed so i had to fill up with shell, starting off for the first 5 minutes i took it easy then i went up to about 4500RPM in third and got a knock reading of 75 on the PFC!!! im gonna wait till this tank runs out & im never going to put shell fuel in there again
Sam, Shell don't sell 98 octane fuel in SA, so if your car was tuned using BP Ultimate 98, putting Shell Premium (95 RON) is definitely NOT a good idea with an ECU with no knock control.
To be honest mate, I'd drain it and refill - it might be $60 worth of juice, but how much was that rebuild again? A LOT more.
Oooo, i havent been on a good run for ages! nice weather at night now for it, can actually get out the car and chat without getting drenched.
Also, I'm going for the Microtech to solve my problems, so car should be back at christmas time :(
hope all goes well for ya steve :D
thanks for that info will, i didnt know the shell was only 95RON.
i didnt put much of the shell fuel in there, just enough to get me by. so today i filled it up the rest of the way with BP and its running all good now.
from what ive read the knock reading of 75 isnt too serious, but ive learnt a lesson there.
with that first 4000RPM right before the boost really kicks in, the computer over-richens the air-fuel ratio, not sure why, but thats why it goes all flat. i noticed my car used to back-fire a lot around those RPM, but now it rarely ever backfires
i was originally going to, but i ended up getting it fitted & tuned all in one. i also needed a bosch fuel pump, cos the stock one was running out of puff. i got boostworx do do mine, they did a top job. but i also heard good things about graham west too.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
