  • Replies 6k
Posted Images
went on a mini cruise last night with 3 other GTRs, 2 WRXs, and a RX7 S6 to Lobethal and back. Had issues with losing cars in traffic though. Engine was hot and brakes not as reponsive on way home but it sure was fun!
not sure about that one.
i always put BP in my car, execept i ran out last night & the BP was closed so i had to fill up with shell, starting off for the first 5 minutes i took it easy then i went up to about 4500RPM in third and got a knock reading of 75 on the PFC!!! im gonna wait till this tank runs out & im never going to put shell fuel in there again
Sam, Shell don't sell 98 octane fuel in SA, so if your car was tuned using BP Ultimate 98, putting Shell Premium (95 RON) is definitely NOT a good idea with an ECU with no knock control.
To be honest mate, I'd drain it and refill - it might be $60 worth of juice, but how much was that rebuild again? A LOT more.
Oooo, i havent been on a good run for ages! nice weather at night now for it, can actually get out the car and chat without getting drenched.
Also, I'm going for the Microtech to solve my problems, so car should be back at christmas time :(
hope all goes well for ya steve :D
thanks for that info will, i didnt know the shell was only 95RON.
i didnt put much of the shell fuel in there, just enough to get me by. so today i filled it up the rest of the way with BP and its running all good now.
from what ive read the knock reading of 75 isnt too serious, but ive learnt a lesson there.
with that first 4000RPM right before the boost really kicks in, the computer over-richens the air-fuel ratio, not sure why, but thats why it goes all flat. i noticed my car used to back-fire a lot around those RPM, but now it rarely ever backfires
i was originally going to, but i ended up getting it fitted & tuned all in one. i also needed a bosch fuel pump, cos the stock one was running out of puff. i got boostworx do do mine, they did a top job. but i also heard good things about graham west too.
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
