  • Replies 6k
Posted Images
id go with whatever gives me the most torque and if im not wrong the 25/30 comes 1st in this department followed by the 25det.
is that turbotech bleedvalve your using the same one as what is/was being sold on these forums? they work an absolute treat. alot better then my ebc, suprisingly.
yeah prob 25/30 but i love the gtr engine torques good but i still want ti to rev out just a little bit... not like a rb30et.
anyways yeah the turbotech it is works a treat
The RB30 does rev (refer to Bu5ters) BUT you need to run a nice big turbo and nice manifold otherwise you will pretty much always make your peak power between 5000-5500rpm. :woot:
Sky30's is a prime example of this. Huge GT35R turbo yet it still only makes its peak around 5500rpm, he dropped 260duration cams in it and made ZERO difference to where peak power is made. An exhaust manifold that can handle the flow (rather than the stock log item) is needed, sure you can dial in more boost to make more power but the peak rpm power is only going to become shorter and shorter.
Have any of you seen silloute88's 3rd gear burnouts? If that aint reving what is... :thanks:
That is making slightly approx 230rwkw I think it was on 12psi.. Would have to double check that, he said it pulls ard all the way to 7500rpm.
BUT he is running a nice turbo and manifold setup.
Then if you consider flicking it past 7000-7500rpm you want to make sure you have a proengines oil pump drive crank collar fitted and possibly an ATI balancer.
But this is the same for an r32 RB26 also. If you want to rev it and not break oil pumps you need either the crank collar or an R33 gtr crank.
yeah ur right ive seen 88silos burnouts marks a big part of r31club aswell. lol
im happy to rev up to 7. all in the future the main thing was that i was happy with my result on 1bar and that it could make alot more with boost raised to whatever is safe
Edited by r31turbo
car would weigh 1400 tops as ive been trying to save weight whereva possible... removed hicas + abs + alot of other crap... im trying to get it to 1300 ill have to weigh it
i hold my car in high regard as even though i know r31s arent everyones cup of tea i am an enthusiast and i paid alot for this car over a r33 and over importing and complying a 32gtr.
Edited by r31turbo
Hey thats great to hear
yeah tis good, but theres so much shit wrong with it, got some rust
the interior looks shit as, got no key for it :P , needs new shockers
needs all windows replaced, coz they've all got yellow paint on em
probably has alot more wrong with it but yeah, i'm gonna have no
money left :
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
