  • Replies 6k
Posted Images
id go with whatever gives me the most torque and if im not wrong the 25/30 comes 1st in this department followed by the 25det.
is that turbotech bleedvalve your using the same one as what is/was being sold on these forums? they work an absolute treat. alot better then my ebc, suprisingly.
yeah prob 25/30 but i love the gtr engine torques good but i still want ti to rev out just a little bit... not like a rb30et.
anyways yeah the turbotech it is works a treat
The RB30 does rev (refer to Bu5ters) BUT you need to run a nice big turbo and nice manifold otherwise you will pretty much always make your peak power between 5000-5500rpm. :woot:
Sky30's is a prime example of this. Huge GT35R turbo yet it still only makes its peak around 5500rpm, he dropped 260duration cams in it and made ZERO difference to where peak power is made. An exhaust manifold that can handle the flow (rather than the stock log item) is needed, sure you can dial in more boost to make more power but the peak rpm power is only going to become shorter and shorter.
Have any of you seen silloute88's 3rd gear burnouts? If that aint reving what is... :thanks:
That is making slightly approx 230rwkw I think it was on 12psi.. Would have to double check that, he said it pulls ard all the way to 7500rpm.
BUT he is running a nice turbo and manifold setup.
Then if you consider flicking it past 7000-7500rpm you want to make sure you have a proengines oil pump drive crank collar fitted and possibly an ATI balancer.
But this is the same for an r32 RB26 also. If you want to rev it and not break oil pumps you need either the crank collar or an R33 gtr crank.
yeah ur right ive seen 88silos burnouts marks a big part of r31club aswell. lol
im happy to rev up to 7. all in the future the main thing was that i was happy with my result on 1bar and that it could make alot more with boost raised to whatever is safe
Edited by r31turbo
car would weigh 1400 tops as ive been trying to save weight whereva possible... removed hicas + abs + alot of other crap... im trying to get it to 1300 ill have to weigh it
i hold my car in high regard as even though i know r31s arent everyones cup of tea i am an enthusiast and i paid alot for this car over a r33 and over importing and complying a 32gtr.
Edited by r31turbo
Hey thats great to hear
yeah tis good, but theres so much shit wrong with it, got some rust
the interior looks shit as, got no key for it :P , needs new shockers
needs all windows replaced, coz they've all got yellow paint on em
probably has alot more wrong with it but yeah, i'm gonna have no
money left :
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
