  • Replies 6k
Posted Images
when were you sneek off to oran park mate, pit crew?
Yeh mate, helping my mate with his Saloon Car, will be on Speedweek on the 12th Nov i think. if you watch it he's #80 in a falcon! Left Thursday morning at 4am towing the car, and got back 8am Monday, you could say a quick trip! :happy:
I could have got some silver tint but it would have cost alot more than i paid ;)
Some of the guys at wynns can do some great tint jobs. i'll try and get some pictures of our tinters car when he gets it back. he has silver tint with flames cut out and red tint for the flames
just thought id mention im an idiot
left my lights on 2day 4 some reason
went 2 jump start my car
and somehow put leads on wrong way and by the time i realised the leads were melting, i heard weird noises n smoke everywhere lol
then it took about an hour afta i started the car for everything to seem to go bk 2 normal. my alarm was making wierd noises but then started working again after a while
any1 know if i would have done anything bad to the car? would have been connected for about 15 secs.
that doesnt sound good at all mate. but to put your mine at ease, an alarm making funny noise is a concern. although mine played up a while back in winter just before i fried my starter motor but its fine now.
been driving all day 2day, seems ok.
although i think ive detuned it, it really laggy and loose power over 4.5k
time 4 a tuneeeee
also need to get front pads, any1 know the type they r, cos every time i go mechanic he had to take them off, trace them and fax 2 his supplier 2 get the right ones in, so i wana know wat type so i can go get the myself
Edited by vange
lol your lucky.. I bought a new battery, bloke asked me what side i want the positive I said top right. Got home, it was going dark, couldn't see too well hooked battery up. Upon touching the last terminal i saw a big spark and a big crack noise from the fuse box.
Blown powerfc, blew multiple cheap fuses under the dash and an expensive $35 75amp fuse in the fuse box.
It was a cheap batter so it had the + and - pressed in to the top plastic, so not easy to see at night. :P
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
