  • Replies 6k
Posted Images
WOW whiplash that was amazing
pixel8r i do find parking not allways easy in my line 9 times out of 10 i take 2 stabs @ getting in parks and u-turn i cant make using 3 lanes it takes a good 3.5 lanes where normal line will do it in like 2 lanes to 2.5
We had a new Silver GT stolen from work friday night!!!!!!
the keys got stolen on friday and they came back for the rest of the car during the night. Two sets of Gates were cut through to get to the FPV.
not expecting to see it in 1 piece again
:P:(
yeah true but who reviews a car like the gtr and complains because you cant park it easily? So you may have to do a 3 point turn instead of a u-turn - they made such a big deal over it...
I'm not always good at parking in my stagea and sometimes I take more than 2 goes (lol) but its the kind of thing you get used to and you just park, get out the car and not think twice about the fact you took 2/3 goes to park it right...
Anyway, there are a lot of things about that review that made me think it was biased. Obviously no mention of the gtr gearboxes since that would spoil the wrx comparo lol :laugh:
anyways....moving along... :P
I just had to say, last night I had to really USE the brakes in my 33 GTST for the first time, and the stopping power was incredible! Standard brakes and normal discs, 18" rims on 235's all round, coilovers.
My old car had ABS and so I was never sure what to expect from these when I really locked them up. Slowed me right down until it locked up, and even then it stopped in its tracks. Very impressed, and I'm very happy that myself and my passengers are quite safe in this vehicle.
Me little piece of crap Corolla got defected on Friday night............ They defected it for having the track out of the guard on the drivers front wheel, and on the paperwork they put down it was a MAJOR defect, so i questioned him on how it could be a major defect and why he is sending me to Regency and why i couldn't just go to Sturt Cop Shop, and unfortunatly he showed me the book and wasn't much i could do.......
In saying all of this the cop actually rang me back the next day(must have been thinking about it/me) and said that i could take it to Sturt Cop Shop, I was cheering, couldn't believe my luck!
What a load of crap in that Autospeed review of the GT-Rs about never being able to relax while driving, put your arm on the window etc. Mine drives just as smooth as any other car I have been in.
Perhaps it's because they were reviewing a V Spec, and mentioned something about it having negative front camber :S
so non ABS brakes are better than ABS, can u tweak ABS to no go into ABS mode at the first sign of 1 wheel slightly locking due to loose or bumpy surface where all other wheels are not in danger of loosing traction
EDIT
just went to boostworx from slimjims sig
needs updateing
SAU dyno day
Edited by Madaz
Sounds right for a 100% stock GTR. :laugh:
Thats around 220-230fwkw.
(just realised fwkw here means 'flywheel kw')
270Nm wouldn't be right either would it - not sure how torque goes at the wheels in a manual. In an auto torque is multiplied at the wheels due to the torque converter so you get very high torque figures in autos generally. Not sure if the same is true for a manual tho - but 270Nm is definitely low...
173kw at all 4 would be about right for a stock GTR. Doesn't sound much but remember max power is only part of the equation. Its all about how quickly you get to that figure, which is where torque comes into play. Pretty sure GTR's have 400+ N-m at the engine - and every bit of extra boost will see this figure climb upwards...boost=torque.
Torque measured on a chassis dyno is dependant on things like gear selection, dyno roller radius, wheel and tyre size, torque multiplication via converter if auto, etc etc etc - about the only thing you can compare is two identical cars on the same dyno in the same gear with the same wheels and tyres at the same stage of wear.
Engine torque is a meaningful comparison, but difficult to measure or estimate from chassis dyno figures.
Thanks for that - I knew there was a reason you couldn't compare torque at the wheels from dyno readouts - but never knew why...
cheers. :laugh:
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
    • wedding eh.....I seem to get to more funerals than weddings or christenings these days....
