  • Replies 6k
Posted Images
why is there no race tracks??
They have tracks:
Kwinana Drag complex which is similar setup to WSID (good facility!!)
Barbagello (where V8 supercars run each year)
So they have better facilities than us as we dont even have a drag strip!!
Do you mind me asking what you study at uni?
And i agree gotta love companies paying for hotels and meals. taxi's, etc, etc.
I'm completing a double of Chemical Engineering and Finance :blink: *sigh* finally on my last year
There is plenty of work out there but I always worry that I wont find a job! A lot of companies have great graduate programs. I'm think minerals proc/mining or oil & gas...
At the moment I'm happy to move away or stay in SA...
im about to murder someone.
i need to be up for work in about 5 hours,
and for the last 90+ minutes ive been kept awake by the noise of a droning diesel engine somewhere nearby..
how very f**king annoying.
Any one have a link to the rb30 conversion, iv looked at the one on SAU but it too long 290+ pages
Need info on whats needed. Iv got the rb30e from a 89 r31 and my top end from my 33 gts-t. Iv got around 8 grand to put into my engine (internals) but have been thinking of the conversion any info would be goood
this is your wasteland?
:excl:
Yes, this is our wasteland
LOL, You call it that but really it isnt :P
Hmm I need to speak to you about something :wacko:
Will email you tommorrow :)
sif still on the same page peeps....your wasteland is the ghey! :laughing-smiley-014:
get pauly in here to whore it up :laughing-smiley-014:
Well, rather than starting a new thread, I thought I may do a little re-introduction of myself here ;
My name's Lee, and recently I purchased an R33 GTS-t. I've been a member of SAU for almost 3 years, the amount of time it took me to convince the wife a '33 was a good thing to have! LOL
I've been interested in imports for about the last 5-6 years, but took me till now to be in a position to buy one. I'm 26 now so insurance is reasonable (at long last) and I finished my studies in Electrical Engineering just under 18 months ago (end 2005). I now work as an Electrical Engineer in the city, and some of my previous cars I've had have been:
75 GC Galant (first car)
81 XD Falcon S pack
95 EF Fairmont
91 R31 Silhouette
96 EFII Fairmont Ghia (Manual!!)
and now my R33 :)
I also currently own a 2006 Mazda SP23 which is the daily. Well its sort of mine and my wifes. I drive her to work in the SP23 most days, and take it on to my work. But if she needs the car for something else that day, I drive the '33
So a little about me to revive this dead in the water wasteland!! :D
Not sure how many other people are recent members or been hiding in the dark so some intro's of yourselves would be good to get to know people. I plan to make it to some cruises, but work and family generally restricts me to Sunday Cruises, so need more sunday cruises!! :woot:
Edited by Hotwire
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
