  • Replies 6k
Posted Images
picked my car up at about 5pm today.. pulled over by the cops for the first time around at 9pm (no defect thank god!!)
"the reason we pulled you over is because your licence plates dont exist"... doh!! =P
mum was in the car at the time, and i just laughed.. was all good, the cops were pritty cool about it all *phew*
:P what the first day.....lol
How does it feel to drive a GTR??
this IS a wasteland.
Ah true, true! :P
By the way has anyone heard of:
"Nano-Technology Gasoline Saving Pad + Auto Booster
This set of items can save up to 30% of fuel,boost horsepower and many many more. Very easy installation."
I found it on a notice board at uni...
Has anyone tried it?
Paully,
Wait until you get a little older buddy... That back and shoulder hair begins to get a little longer; its quite disturbing when your outside doing a little gardening wearing a tank top and you have to pick fly's out that become trapped in your shoulder hair. :S
I'm wog too.. Northern
Paully,
ewwwwwwwwwwww, looks like i won't be sleeping tonight :P
Paully,
Would never have thougth you were a wog cubes, im southern, Nap & Sicilian.
ahh astro i wouldn't believe that if i were you.
I’m sceptical too!!! these engineering students are always coming up with some new ideas that 'work'. I'd be more inclined if there was some data behind it... or maybe if someone credible had tried it
It doesn’t hurt to ask though
Good ol' Adelaide Uni :laugh:
The Adelaide Uni Eng students have the Biggest pub crawl in Adelaide- so thats what swayed my decision. Haha
Nah, I was thinking about doing mining eng at Mawsons but I got a better TER than expected so I opted for Adelaide. I'm finishing up this yr...
Happy B'day Ben
Ah true, true! :laugh:
got pics, theres a gizmo 2 mates of mine bought @ auto shops that is ment to reverse charge the fuel or something and get better performance and better mileage
Nano-technology Gasoline Saving Pad -stick underneath the petrol tank.
Its nano-particle can activate and modify petrol’s positive and negative ions, in order to increase combustion dynamicity. That sorta sounds believable...the combustion dynamics stuff
I just wonder if the benifits outweigh costs... If it infact does what it claims.
well i'm pretty happy with myself, i start working (for the dole) on Monday :thumbsup:
it's so great the guy that i saw likes Human Nature, we had a great chat about them
but sadly he's not going to there concert :wave:
oh he said if i do well he'll take me for a ride on his bike :thumbsup:
should be fun, haven't been on 1 in about 15yrs :)
Is he Gay?
and is that his push bike.............LOL
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
