  • Replies 6k
Posted Images
.....Adelaide roads, you just wait till the lines are done on king william and north terrace, we may have to use a hook turn system like in melbourne and 80 percent of dum shits here in Adelaide will have a crash cause they have no clue.
hey paul, dont even speak to ace exteriors... i think they are a scam
^^ dang how you know you lost it?
were they based in adelaide and u direct deposit to his account and now he not anwsering his phone?
hes in Vic, wont answer his mobile or his emails. direct deposited $1840 now nothing has come of it... more than a months wages for nothing. reali upset and bloody pissed off
Is this the mob?
Last modified: 27 Nov 2006
ABN:
88 228 815 716 view historyview history
ABN status: Active from 27 Nov 2006
Entity name: I.A BUKSH & R.M TREGEAR
Entity type: Other Partnership
Main business location
State: VIC
Postcode: 3976
Trading name(s)
Ace Exteriors
James Home Services - Window & Exterior House Cleaning
Other registrations
GST status: Not currently registered for GST
Deductible Gift Recipient: Not entitled to receive tax deductible gifts
The only ACE exteriors I found in VIC.
Or one mentioned here?
http://forums.ebay.com.au/thread.jspa?thre...d=1179308527378
Edited by Howie
adz u gotta call the cops man. ring the bank see if they will cancel it or use any powers at all to help you, theres 3 ppl u gotta call and they try to make it hassle free as possible.
rang the bank, nothing they can do its already gone through. emailed the cops they said to come in and make a report and theyll gone from there... so yer after work.. yay!
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
