Hmm nice...
Cause I have a mis fire issue at the moment in the GTR so might be upgrading the coil packs to splitfires and they are good!
Did you have a mis fire shaun? or just upgraded for the hell of it?
Phew!!!
he had a freakin crazy misfire, wasnt fun.
Yeah it does come down to price doesnt it...well I hope it all goes well :)
heh, always comes back to money.
the gtr's still on the list, but i might wait til im in another job.
  • Replies 6k
Posted Images
Aww Coil packs are a common thing to break :thumbsup: and looks like that will be my problem also...My car sounds like it has some lumpy cams, its cool but for the wrong reasons :)
Thats fair enough.... so what is this soarer..... year,colour, mods??
So we should expect you on the cruise this weekend Shaun :)
Probably not as not sure how long it will take them to do my front bar as they are quite busy at the moment.
I hope to be out though with the top secret front bar in place though.
Mine sounded like a WRX on roids. lol
It wasn't good at all, now sounds like a skyline and goes heaps harder than before.
Big thumbs up to splitfires, well worth doing even if you dont have a misfire.
silver(ish), grey leather int, comepletely standard, lol, tis just a cruiser.
but after just stepping out of a friends gtr... guh, lol, might end up not buying it, ah, decisions decisions.
Edited by scandyflick
LOL My sounds like a dragster at the moment
Where did you get your split fires from?
Glad she is all fixed up !
Oh so nice then.....I like a cruising car they are cool ;0
LOL you are making it hard for yourself but should rush into it!!
any1 here watch the Today show??
they were in Adelaide this morning hehe, i got there at like 5am
just so i could see Human Nature :thumbsup:
my friends mum was saying that they had the cameras on us alot lol
oooooooooooo i hugged Humphrey B. Bear :(
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
