Im a regular parmy eater.
THE absolute best parmy I've had quality and taste wise has to be from Billy Baxters in the Myer Center. The sauce they use is awesome, so awesome I've sifted through it with a fine tooth and comb and then copied the ingredients back at home.
A few Kalamata olives (do go light on these), a little capsicum few herbs and spices, fresh diced tomato's, olive oil + simmered for a while but add the capsicum a few mins before you pull it off the stove = FTW. :P
Don't go adding sugar to remove the tomato's tang/acidy taste, buy a better/different brand and or simmer with plenty of olive oil. Just the olive oil along + simmering is usually enough to bring the acid/tangy taste out of it.
The chicken they use is a good quality breast fillet, no brown bits no fat hanging off the end its all cleaned up nicely. And its FAT, not a bashed out or chopped in half through its guts chicken breast.
That massive parmy I had on one of the SAU meets I was a little dissapointed.
The Sauce was shit, no thought went in to it at all, it looked like tomato paste slapped on top, the chicken its self was thin and wasn't of the best quality, I had a few hard bits, black and fatty bits. :S
Billy Baxters in the Myer Center = Chicken Parmy FTW!
  • Replies 6k
Posted Images
yeah was trying to be comical Luke forget where that line is from or how it even goes 100%
may be from the simpson's as all good things are
Flick been thinking and you may not have seen the 2nd rendition of your sig so i will point it out again and drop them back to back if you prefer the first then keep using it but take a look @ the 2nd also :laugh: and now 3rd :sorcerer:
1st you current one
2nd rendition
3rd rendition just did this one then after looking @ the preview post for a bit
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
