  • Replies 6k
Posted Images
Had my 33 on the Dyno at Boostworx today, 159.1rwkw with just mushroom pod & cat back exhaust. Pretty pleased with it.
An interesting side note, is I tried using the Datalog Dyno software the other day that utilises the consult port/cable, and with that software gave an indication of 160.5 rwkw. So I was surprised to see it was quite accurate. The 160.5 was a figure with the correct air temp and atmospheric pressure correction (from BOM website at the time) so if anyone want's a cheaper way to check your cars output, I can reccomend using it :D
does anybody else think/heard that boostworx duno reads a lil high ?
There's a LOT of variables.
Placement of inlet air temp sensor, how the car is strapped down, tyre pressure, shootout mode run etc etc.
Its fairly easy to see a variance of 5 even 10rwkw depending on the above.
I believe it actually reads pretty much spot on if not a touch low. R33's with PowerFC's generally see 190-200rwkw; with cam gears or a 13+psi 210rwkw is achievable.
Mine was maxing out the afm and injectors at around 180rwkw; another mates also max'd his out at the same power.
BUT just because the afm is max'd out it doesn't mean you can't go on to make 220rwkw with the stock afm. Its just that the tune is a tad crude but it works.
    • Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
    • Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
    • Ok. And Nistune? I read (here too) mainly on Stagea threads that it can by "turn off" with Nistune. But they say they still had the sensor plug in. Next week iam going to the Nistune(and other ECUs) tuner so i can finally make it work. I drove the car home and apart from the cut it drove great. No misfire no smoke no hesitation or rough start...so hoping it is this sensor that is missing
    • I just stack 2 pieces of 200x50 timber on top of each other. Total length about 900mm, with the top one being a little shorter and both having a 45° angle cut on them to make the front edge a bit of a ramp. Put these in front of each front wheel, drive up on them, throw the trolley jack under. Takes 1 minute. Scissor jacks can eat a bowl of dicks. I never use on under my car unless desperate.
    • Well, yeah. But I just expect everything other than my car to feel like a bucket of shit anyway. I still miss my Alfa 116 so much though. You could run over a 20c piece and tell whether it was heads or tails.
