  • Replies 6k
Posted Images
Sept 10th at Boostworkx
Fit cam gear (supplying group buy Aerospeed item)
Install Oil filter relocation kit (supplying Greddy item)
Oil change (z145 oil filter + Motul Turbolite 4100 oil)
Attessa Flush with genuine quality fluid
Retune inc remove and refit tailshaft (safc / sitc / 15-16psi not sure yet)
Install braided lines and bleed system (supplying Maltech lines and Castrol super response dot4 fluid)
Install Front rotors and pads (supplying Dba slotted rotors and Bendix advance pads)
got a good quote, so Im happy with that.
cant wait
looking to "feel" around 200awkw I suppose.
nice tangles. 200awkw is ballsy.
lol, cheers :laughing-smiley-014:
blue-ballsy ?
hahaahah
yeh, at the end of the day, I bought the Stagea 2 years ago with an overall budget of 30k in mind (incl 18k for car) and a setup safe for 200awkw. which is what it'll be. brakes/suspn/engine all "tuned / setup" for the HP output.
only thing missing would be the auto tranny to be serviced + shift kit; all in good time tho.
Brendan - sorry i didn't catch up with you this week i been not well since Wednesday i thought i was going to catch up with you on fri but got worse then i couldn't even talk had to get my mum to ring my boss to say i wasn't going to work ... is there an emotion for how embarrassing ;)
anyways im feeling a little better now so i imagine i will be able to catch up this coming week
well im back @ work i finish @ 3:30 Brendan i will run by the city on my way home :cheers: but where excactly will i be running when i hit north tce if i ring you are you able to meet me on the street jump in the car run around the block and drop you back :P or something like that so i dont have to get a park
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
