^Flick, sounds like any 2nd hand car unfortunately..... My skyline is similar, needs new clutch, new tyres, new plugs, etc. etc.
Of all the cars I've owned the only one with the least problems is my SP23 which I bought brand new. And even then there have been a few issues (cruise f@#ked up), just warranty has covered them. Thus is the joy of cars :P
  • Replies 6k
Posted Images
All but car 4 owned at the same time :
car 1) Clutch, turbo, intercooler, engine, clutch, turbo, exhaust, afm, right rear trailing arm ripped out of chassis, diff and that was in just over a year :P
car 2) Blew up engine, SOLD lol
car 3) Gearbox, injectors
car 4) Not to much apart from hitting a pothole to hard and breaking something. I treat the 180 like a cheap whore and it just takes it, I love this car.
thanks Jess
have you had a chance to look around @ 5 stud hubs
i found a topic but cant find it quickly here basiacally some guy selling front struts to stagea with
R34 fron rotors and calipers and rear 33 gtst hubs and calipers
ive got my front rotors and calipers will talk to a guy about getting his rear end rotors calipers and hubs
then to my knowledge all i need is front hubs to suit ATTESSA
cheers madaz. Saw the pics last night, was too tired to reply - but they arent showing up now?
Weird seeing my car in different colours lol but i stuck with the first one u did (original colour :action-smiley-069: ) Thanx!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
