^Flick, sounds like any 2nd hand car unfortunately..... My skyline is similar, needs new clutch, new tyres, new plugs, etc. etc.
Of all the cars I've owned the only one with the least problems is my SP23 which I bought brand new. And even then there have been a few issues (cruise f@#ked up), just warranty has covered them. Thus is the joy of cars :P
  • Replies 6k
Posted Images
All but car 4 owned at the same time :
car 1) Clutch, turbo, intercooler, engine, clutch, turbo, exhaust, afm, right rear trailing arm ripped out of chassis, diff and that was in just over a year :P
car 2) Blew up engine, SOLD lol
car 3) Gearbox, injectors
car 4) Not to much apart from hitting a pothole to hard and breaking something. I treat the 180 like a cheap whore and it just takes it, I love this car.
thanks Jess
have you had a chance to look around @ 5 stud hubs
i found a topic but cant find it quickly here basiacally some guy selling front struts to stagea with
R34 fron rotors and calipers and rear 33 gtst hubs and calipers
ive got my front rotors and calipers will talk to a guy about getting his rear end rotors calipers and hubs
then to my knowledge all i need is front hubs to suit ATTESSA
cheers madaz. Saw the pics last night, was too tired to reply - but they arent showing up now?
Weird seeing my car in different colours lol but i stuck with the first one u did (original colour :action-smiley-069: ) Thanx!
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
