yeah, i didn't realize it was the grand final until yesterday when i read it in the paper :P otherwise i would have booked last week. although it would have been better for me if port had lost on the weekend :whistling:
any one else bored?
Edited by Whiplash
  • Replies 6k
Posted Images
yeah board played sof2 RD before got like 80kills 25 deaths
waiting for Luke to hit me up for a game :whistling:
should goto bed soon too
my alarm on my phone tells me how many hours till the time that is set is and i came to the conclusion that i get way to little sleep .... but i already knew that didn't need an alarm to tell me that
Whats the reason for formatting the HDD? is it simply to "clean the crap"?? reason I ask is my laptop seems to be getting slower, had it for a year now. I figure its getting full of "shit" and wondering how to speed it up again?
lol i started to loose thing when it was partitioned, could never remember where stuff was stored :whistling: i got all my 3d stuff to reinstall tomorrow night so that will give me something to do :thumbsup:
for me usually because it starts getting errors and issues - i need to be more careful against viruses ect lol
Edited by Whiplash
yeah Lee to clean crap up from the million and 1 installed demo trial and real programs
registry is a mine field
yeah i agree Luke I've had people tell me registry mechanics are good but i havnt seen one that returns windows back to what it was like after a format
just to get that screen up took 2-2.5 secs and to load into windows @ the screen where the bar scrolls i think it scrolls like 14-16 times and a fresh install it scrolls like 4 times
slim on the front look better IMO. You need to get a good number though :D which branch would you go into to get them??
Yeah I was thinking fat on back, slim on front. I went into Mitcham and asked if I could choose but they said I get what's in the box... assholes.
Which branch do you suggest?
lol none now i tried to get a set of plates for a customer (triple or double no) and now i only get whats in the box :D damn new computer system
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
