  • Replies 6k
Posted Images
The easiest and cheepest way was to get it fitted by a workshop (I used Morpowa) because GCG offered a discount if a workshop fit it. The discount payed for the installation and tune.
so it was as simple as, drop the car at Morpowa and they do all the rest?
as your likely to get a new/reconditioned turbo sam, do you have the necessary support mods yet or are they coming?
Im organising a power fc too, injectors should be fine at the boost levels i'll use, im pretty sure ive got an upgraded fuel pump too, but i need to check that for sure :)
i know of one workshop that charged my friend $900 for a turbo install. Is this a resonable price - you dont have to state how much you paid guy just your opinion and other ppls opinion in general.
That sounds a bit expensive. The job is easy and quick enough on an R33. I paid less than that and the job included shipping, new coolant and oil, and time on the dyno to reprogram my PFC.
I guess if it wasnt an R33 then that may take a bit longer.
Yes.
Took nearly 2 weeks (but we did it on the 2nd of January and shipping was a bit slow due to the x-mass new-year holliday rush. I think its about 1hr to remove turbo, 1 hour to install then dyno time.
i think it was a HKS GT2530 on R33, right duc? they require some mods before they fit up
It would be wise to install injectors aswell.
I have a rising rate reg, and bigger fuel pump but I am limited to 14psi boost because my injectors are already at 90%. With injectors I shoud get over 250rwkw.
shouldn't be anywhere near that expensive unless custom work has to be done. Both times my manifold had been removed it only cost $400 (not quite as big job as fitting a turbo, but damn close).
Unfortunately it was a 33. im sure replacing the turbo was a quite straight forward process even with some fabrication for the oil and water lines if required. The labour did not include any form of tuning. I personally believed he was ripped off.
yeah it was sam, you know the guy im talking bout. I feel sorry for him. Damn workshops prey on those who dont know any better.
Hey guys
           After reading all of this... Do you reckon I need more stuff for my car. e.g. upgrade fuel pump,etc.. I've got the power fc, avcr, frontmount, ..
what next? Or will it be ok?
Cheers
Iceduck:)
Have you got all that gear installed yet duck?
Thats weak, hey. Just make sure we never take any business there. Yeah, for sure they ripped him off, they probably made about $450 an hour out of that job.
there are certain aspects that they are good at what they do but it just seems that if they can take advatage of you they will.
They do anything to make an extra dollar. Can you PM me the name of the place? i forgot already.
definately agree. aftermarket injectors i.e 550cc variants wouldbe a good investment. I believe rising rate regulators are just a band aid. AI'd rather my duty cycle to be lower, more opportunity to get the most out of your turbs.
Yeah, injectors are on my list. right after i save a bit more money, these mods are a big drain on the bank account
Guest
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
