Just wanted to know what the penalty for underage driving.
As in what would be the penalty if someone under the age of 16 (without learners) was caught driving?
Would this change if someone was in the car?
I'm in no way considering doing this, but I am just curious as to what it was because i have heard a few stories of people driving under the age of 16.
https://www.sau.com.au/forums/topic/148612-penalty-for-underage-driving/
firstly you get rapped, then you get rapped again then later on you get rapped again. Then you get told you can't get your learners for a long long time.
Wrong,
If you have your L's you wont get in much trouble. Just a $200 fine and a slap on the wrist.
But without L's im not sure, maybe even less or more.
No learners and the fine will be 537 for Unlicensed driving Penalty notice only.( Code2107 RSA 18 am reading the code book) If you have learners and no full licencesed driver in car it's a court appearance most likely less fine but will affect getting licence. Getting penalty notice only should not affect getting licence/permit.
Wrong,
Are you retarded? He clearley said if you don't have your L's.
Is it still possible for young guns to take a car out on a track and have a spin.
I used to go out before I had my L's with a friend and drive round uni's monash clayton and bundoora latrobe are both good. I used to go there weekend evenings so not many other cars around, good for a bit of not so on the street practice.
FARK!!
I'd hate for that to happen.....
What about things like motorkhanas and all that??
Join SAU VIC (assuming you are from VIC) get your CAMS licence, then participate in our track/motokahna/drag/drift/driver training days.
well i know for fact that if you drive with only ur L's you only get a $70 fine for driving unaccompanied. i know this because in my stupid youth i did this and had an accident....someone turned into me and even tho it was there fault i still copped it and had to have the incident investigated by the insurance company, nothing happened with regards to me getting my license later on.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
