Hello everyone!
As much as I do love my $100 turbosmart Bleed Valve I know that in every mans life there comes a time to upgrade to an Electronic boost Controller, what advantages do these have over the bleed valve other than the spikings sometimes in the bleed valves? is it worth the extra hundreds of $$$$ is lag lessened that much?
What brand are good and do the cheap Trust Profec B do the job?
If any of youguys know of someone who is selling a electronic Boost controller in the near future for a cheap price let me know...
I was looking at the Trust Profec B something minimal as far as electronic boost controllers go but effectove i hear and only about $400....
https://www.sau.com.au/forums/topic/14874-electronic-boost-controller/
the profec b's are fine. they do have the function GAIN or fuzzy logic or whatever trust call it which is supposed to reduce lag. basically it holds the wastegate shut until the desired boost pressure is reached rather than 'bleeding' off the air. it depends from turbo to turbo how much an EBC reduces lag, but dont expect miracles
the biggest advantage is now youve got an electronically controlled solenoid which you can adjust from inside the cabin depending on driving conditions or how hard you want to drive. so you dont have to hammer the car all the time. this is the biggest advantage i found from the 'upgrade'.
Originally posted by GTS-t VSPEC
I have a Blitz SBC, and while it is great if I had known that my engine management would allow me to control boost then I'd have saved my money.
See'ya:burnout:
Then will you be sellling it? Also whats the hybrid one from Hikari like?
I do like the Profec B nice and cheap and has 2 levels of boost setting to choose from... this will be nice in the wet weather of winter!
How can he be a guinea pig if no one is using it and everyone is recommending blitz....
it is $320 from Hikari
Someone in WA is using one with nothing but praise. I cant remember who though... is a little cheaper than the blitz, but I have also only heard good things about all blitz stuff
search search search dood, i swear there is a good thread about these EBC's
Guest RedLineGTR
Check this tread out, some comparisions of boost controller, thoe not on a skyline, still some good info and comparsions on holding boost, i assume it will do the same on a skyline.
Hope it helps somewhat. Cheerz ROb
http://www.skylinesaustralia.com/forums/sh...&threadid=13873
i recommend the HKS EBC.
I use to have problems with it when it first came from japan with it spiking and whatnot, but i pulled the pipes off and gave it a quick clean and now its working. And does so quite nicely too. :-)
Shaun
if u get the hybrid i will kill u
never heard of it and no one seems to use it
u wanna be the giunea pig
plently of people use these units...?!?! works auto sell them, simon uses one in his R32.
nothing wrong with single solenoid, the majority of budget-priced EBC's use a single solenoid.
I use Hybrid on my car, Works uses it on his car, don't diss what you haven't tried
As a comparison to my old turbosmart bleed valve, this unit is AWESOME ... after paying approx 340 for it, I came to the conclusion that it would be useless paying anymore for an ebc, since this unit jumps to boost, and holds it there tight
And was piss to install too :D
It is only restricted to 20psi if you use the 2BAR MAP sensor, however you can upgrade them and run higher boost ... but noone here is running more than 20 anyway :P
    • Hey crew, Failed my WOF cause of a lower control arm, and I've decided to hit both arms, and also the compression rods at the same time(seems they're gonna be the most likely upcoming failure points from some discussions with the lads over on the G35 reddit). I've looking at these form Z1:  https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-compression-rod-p-40716.html https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-lower-control-arm-p-40674.html I asked Z1 if they'd work as it's the same platform, just RHD vs LHD. I basically got told "Lol dunno". Specifically they aren't aware of any difference but can't guarantee fitment as they haven't done it on a 350GT. So guess I'm asking is if there is any issues with using 2005 G35 coupe suspension parts on a 2005 350GT coupe? Orginally I thought it could be something in the way of the arms that each control arm is designed to be positioned around, but that'd be an engineering nightmare for Nissan needing two different shaped control arms 😅
    • ^ This. The mode door actuator is a common failure, as is the actuator and/or the actual valve for the coolant flow control valve. I also don't know how available the mode door actuator is these days. I've been meaning to look into it and get one from wherever is possible, to keep in the shed for the rainy day when mine eventually fails. Anyway, the advice to you is to search the usual NOS part supply places, or even just go to Nissan and see what they list.
    • Have you got a pic of the actuator? My guess is that unit has failed internally and was flopping around, so the previous engineer who owned it forced it to be fully open to cold air (blocking the heater core path). As far as you can tell, is anything else wrong in the system? Likely you just need a new actuator (not sure how available they are) and then "installation is the reverse of disassembly"
    • I'm happy with the Lsailt unit that I put in, it puts full Android on the top screen so you can run whatever Nav and other Apps you want, while still existing inside the factory functionality like automatic reverse cams, audio input switching, retains factory bluetooth etc. Not cheap and the install was moderate (not simple, not hard) Yours is a V36 not V37 though right?
    • Yeap, all the NC's that I originally looked at that had a hard top were PRHT, which makes the roof line look horrible, hence why I said nope to them My only caveat for another MX5 was it needed to have a hard top, and initially I didn't think you could get a detachable hard top for the NC,  like my NB had Again, a big thanks to Matty for helping me source the detachable hard top for my little girl, they are as rare as hens teeth in Australia, and the few people who have them, keep them Also to Greg, for initially pointing me in the NC direction NC PRHT 🤢🤮 Not mine (I really should take more photos of my car), but a NC with the detachable hard top 😁 To me, the difference in how the detachable hard top roof line looks, and how it actually follows the bodies lines, like they do on NA's and NB's, is chalk and cheese compared to the bulbous looking PRHT
