due to the popularity of lunatics such as mario(gtr700) and munro with there crazy gtr's
i have decided to follow in there footsteps and produce my own badass drag car
now my budget is small some may say stupidly spall ($500 to get me started)
but due to no one wanting to purchase my 1981 toyota corroler it has now become the official fatz drag car
my plans r as follows
1. cut the rust out so they will allow it on eastern creek
2. test the bastard
3. stripp the ****er and run it again
10 turbo the standard angine and blow the living *** out of it
11 if its still going run some NOS (fatz and furiuos style)
and so on
fatz drag car
now casue im a tight arse i need all your help
anything you can spare
especially if you have a rb20/25 that you feel like you need to donate to the casuse
all peaple who contribute will get there name writen on the car with no less than one genuine paint brush( in bright pink)
also if you donate this is a hands on experiment so i expect you to drive the thing
if all goes to plan we should be running 12's by christmas and 6's by easter next year.
if nothing happens ill be the dick running 20's in a shit corroler at the creek
lol
pete
and a picture to wet you mouth
https://www.sau.com.au/forums/topic/14878-fatzs-drag-project/
  • Replies 59
I just cannot believe that you people are taking the pi55. We are dealing with a loose cannon here - if we don't humour hum (notice the same spelling) he mite get loaded and drive the thung on a pubic road somewhere and place the sukurity of other rode user at risk.
Pete I happily contribute 48 1981 vintage 750ml KB cans so you can get the welder out and construck the twin exit zorst same as the 31.
BUT..............................I wanna be there to watch!!
ura legend
is somebody knocking my spelling
yea all sticker r welcome.
the turbo install will be as easy as
dude to the budget nature of the car i feel that i might just g-tech it casuse that cost nothing and EC cost 50 bux
urmine- i like it TYPE FATZ
Manjanal- i might ad a WRX bonnet scoup GAFFA taped on for effect
SATO- every time dom has to drive it she says it doesnt work but when i turn the key it fires first time. funny how she always goes for the gtr first
Redline- oh where serious... lol
Bonkers- ill take your 81 kb cans... nothing that a fridge and a fine filter wont fix
i spoke to dom about this project and here oppinion was that we would be better off if someone stole it... so im guessing that is a green light boys
pete
Dino,
I was thinking that a turbo that is under 1500kgs might just be a bit small... maybe someone on the forums works for an avaition company and can pick us up an engine off a jet cheap... and 20,000L of avgas... if the engine is too much trouble then the avgas will do!!!
Imagine a jet engine sitting in the boot of THE corrie!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
