  • Replies 493
Posted Images
nice photos mate.
thanks mr needed-10-posts-to-send-a-pm :)
I hope you'll keep this thread updated when you head o/seas, Sammeh!
Yeah Nick.. i .. should.. keep it updated while im travelling.. No promises though. . . :P
  • 4 weeks later...
it was the last pic on page one... from back in the day it seems. I didn't realise there were 540 pages to follow. I flicked through every single one. Glad I did too. There's some definate keepers in the mix!
I just need to work out HDR, and where to find stolen tetris blocks.
  • 3 weeks later...
  • 3 weeks later...
