hey lads, I looked at doing this to one of my twin turbo pipes (have two), but decided instead to make my own Trust/HKS/Nismo split pipes off each turbo. I have the additional pipework, just need to finish the measurements + get the new rubber elbows (rubber works just as well as silicon + it is oodles cheaper!)
all up, it should cost me LESS than $250. I'll post some pics and details once done :D (don't have a lot of spare time ATM due to my newborne!)
I don't get on here regularly, but will try to finish it off soon...
Edited by DAN00H
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
