Changing the cam timing is not a simple thing. Saying this cam timing for x motor and so on is misguided. There are lots of variables. It isn't somthing you can approach with a 'bolt on boy' attitude and expect to always have a win.
  • Replies 41
Posted Images
does help but youve changed far too much to even get an idea of whats skewed the results, it could be as simple as the afm ducting trashing the afm signal around and bending the tune. or it could be the cams are offset or too big/small etc (i dont know) or it could be something else is wrong, cam timing is wrong, vct is off etc etc...
anything odd in SENSOR SW CHECK when u do a dyno run or drive around?
do the results change if you pull of the afm ducting and leave the AFM open mouthed?
the only way u will know its the cams 100% is to put the old set back in and prove it, then and only then u will know for sure its them and can work out why, currently we are guessing. try and take out some of the possibilities to make it easier to work out which one is the baddie
definately
* get adjustable cam gears.
* degree wheel check the cams initial timing.
* alter timing and fuel maps for every adjustment made to the cams at the dyno.
* unless you have a 'clone motor', cam timing seldom ends up exactly the same as another engine.
* you can alter the shape of the power graph massively with adjustments to cam timing and appropriate alterations to timing and fuel maps, this is a good thing to have access to exploit it!
* a good cam install and setup can take plenty of time to do right the first time (again if your motor isn't a clone of someones that has already done the hard work).
when your motor was rebuilt, have your decked the block, got a different thickness head gasket? All of these will make 0 not zero, on my GTR cam timing found me like 70 kw as they were set incorrectly, and even both at zero was still wrong.
Edited by GTR1993
open mouthed?
its only 4:30 on new years eve and pauls allready vision impared..
as stated on page one.
i replaced the 4 inch elbow from the turbo to the afm with stainless instead of silicone.
yea the block and the head were both decked slightly and im running a genuine nissan head gasket. so it may be a little out, but if anything that would only be retarding the cams a half a degree maybe.
RE: The cam timing being thrown out with the block being decked etc..
Another reason to use a tensioner on the idler side.
The first reason., They are less than half the price from nissan. :)
to true
but why would anyone buy them from nissan?
surely everyone knows you can get the exact same bearings for less then half the cost from a local supplier.
So hows the 10 sec auto 32 going Joel?
to true
lol yes.. :)
I had a couple of bearings pressed in from CBC for all up around $38 or so.
Its interesting Nissan use 2 bearings within the shell where as Holden on their tensioners/idlers use a single bearing. lol.
My 10sec 32.. lol only a few more bits to get.
An example of cam timing changes I can give you on an RB , my old GTR with stock cams ran the happy +2 intake and -4 exhaust with stock turbos.
When the Tomei cams came along I ran +3 and -2 on stock turbos
To get the same shape on the power curve with more power everywhere with 700hp Group A turbos I had -2 and -5. Another guy with the same sized turbos shooting for more power had radically different cam timing again to reflect the rpm and higher boost he was running.
Each step of the way a retune took place.
As a point of interest each tune with the tomei's had the cams set at 0 and 0 at one point. They made less power than stock up top when matched to stock turbos and the power fell off at high rpm particularly with the group A turbos when at 0 and 0 as opposed to other settings.
Porting the heads and enlarging valves also can have an effect as does different manifold designs both intake and exhaust.
You just need to spend more time on the dyno adjusting and tuning for the cams. There is probably nothing wrong at all with anything.
back on topic.
has anyone found there intake vct pulley had slipped or wasnt set at zero?
Mine looks like it hasn't moved from the day it was installed. I'm assuming your talking about the grub screw adjustment on the back of the pulley? I have a stock engine though so just left it alone when installing my cams, didn't go the extra yards to dial everything in.
Just one other thing that may be skewing your results: Is the vct still working properly? Have you done a run with it off and on to see what happens?
Have you looked at the numbers on the handset? stuff like peak afm voltage, peak injector duty and the like to see whether they are significantly down on the old peak numbers? As these are only looking at the engine, rather than the drive line it could give you an indication as to whether the engine is down on power at least.
does the car feal faster i bet it probably does. you have got a highstall.
that will cause a drop in power but you will still have a freaking quick car.
ive seen plenty of drag racing boys who run 10's disapointed cos there highstalled car doesnt make huge power at the wheels. this doesnt mean squat to the times the thing runs. (these cars are high hp cars too)
also u said that u where geting a boost spike to 27 psi and now its stedy at 24 that would be helping the power output.
The spiking boost you previously had with the old setup would have given a lot more midrange compared to a constant lower boost level.
yea im more concerned as to why the power curve is so much lower.
as i now have the poncams in, they should more then compensate for the high stall i would have thought
Sometimes these bigger stallys don't work perfectly out of the box. I would be thinking about tuning it again with a stock converter in it. If the one you have is slipping too much or not locking up properly then your top end will suffer.
Speak to Mike before you try this though. He will definitely have a better idea than me. :P
That said, there are plenty of other sensible things being said in thios thread. It's a tough one and hard to know where to start. There are a few simple and cheap/free things mentioned here that you can do first though.
I personally don't think that just by replacing the cams and keeping them at 0 can do this if everything was done right. Playing around with adjustable cam gears might get you more power but I really don't think this is where your power went.
When I put my poncams in I gained about 30rwkw without even getting it retuned. (Auto) I would also normally expect you to at least make the same power with less boost.
Good luck mate.
  • 1 month later...
When i fitted the 3000 stall from mike in my 33 4door my mph dropped 5 !!
But et's dropped .7 !
When are you going to run the car ? Anxiously waiting for results :P
still no track in SA so i have to wait..
very keen to get an 11 or close too...
  • 2 months later...
Old thread dig up yes i know but curious did you ever solve your problem darren? or is it to this day still a mystery where the power went was it the stall convert or dialing in the cams, Im sure a few people may be intereested to know if they are to follow down the same path
Cheers
A
  • 6 months later...
    • I did end up getting it sorted, as GTSBoy said, there was a corroded connection and wire that needed to be replaced. I ended up taking out the light assembly, giving everything a good clean and re-soldered the old joints, and it came out good.
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
