Hi all! What a bad start of the new year. I try to tighten the nuts to the exhaust manifold (as it is making nosie when turbo kicks in as well as it was loose) and it snapped at the engine block. What can I do now! Who can I go to to get it repair? Hope that will not cost a lot of $$$$. Please help! :P
https://www.sau.com.au/forums/topic/149354-bolt-to-exhaust-manifold-snapped/
I think you need to use a tap and die set on it. Try Greg at Pro Eng. Certain it happens all the time in engine shops. I really dont think it'd cost much at all. Labour component only and if you got a socket on it to snap it off then it wouldnt be too hard to get too.
Depends which stud it is, sometimes you can get a drill and an easy out in situ but if it is not accessible then you will have to pull the manifold off. If you want to have a go at removing the stud yourself, i can lend you the stuff to do it and give you advice.
You'll likely need to remove the manifold [and turbo, dump, water lines, oil lines, intake pipe etc] about two hours work. Then you have to remove the manifold. Use heaps of CRC/WD40 on all the nuts and studs.
Once you have the manifold off [and you could snap a couple more studs doing it yet], see if you can get vise grips etc on the protruding part of the stud and reomve it. If it is too short to do this, then you can try welding a nut onto the end of the stud and then remove it while still warm just like a bolt. If the stud is snapped off at the block then you have to be very careful and drill a hole in the stud and then use an ezi out [this is a mongrel act, plenty of cursing and skun knuckles, but be very careful and patient]. Hopefully all this will work, if you snick the thread while your drilling, you may need to use a tap to clean up the thread before you replace the stud. When replacing the studs {I'd replace all the manifold studs, buy a kit], nuts, and bolts etc use nickel or copper cote antiseize compound. Use a new stud and gasket set/s for all the job. Also get the good studs, there are cheap ones out there that you should avoid.
Cost, around $150-$200.
Too easy isn't it!!!!
Or you could take it to a shop and they'll do the job for around $500 or more.
Thanks for all the advise. The stud that got snapped was the very first TOP one closest to the fan. I really don't want to pull out the manifold and create more problems. I think the best will be driving to a work shop to get it done. If it is too expensive at the shop then I'll DIY. Cheers!
You could try and find someone who does spark erosion. I'm pretty sure I saw a van the other day that advertised it. It's a process where an electrode is used to erode the stud away, followed by running a tap through the hole to clean up the thread. Useful for situations where an easy out is not going to work.
Cheers
Yep, capital thread repair. I forget his name, but he has done my mates car. Does mates rates if you got a mate that knows him. Cost us $60 to remove a snapped Harmonic Balancer bolt. I think its a per bolt basistoo
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
