  • Replies 54
meh, if you're worried about commie drivers giving you a hurry along just go to an auto electrician and get them to wire up a seperate switch/button for your brake lights, so if they are tailgating you just flick it and on come your brake lights :no:.
Or just drive purposefully and painfully slow
Personally i'm not going to be getting the Bee*R rev limiter for fancy flames or popping noises, and you need to remove your cat to get the flames i believe (correct me if im wrong), but, having a microtech i don't really have a rev limiter, so i'd like one :( for safety's sake.
  • 1 year later...
Digging up a year old thread (sorry)...
I'm curious to know that if you have a switch setup on the clutch pedal for 'Rev2' on the Bee*r limiter and the limit for Rev2 is set to say 4000rpm, what happens when you are about to hit normal limit of 7000rpm and engage the clutch to change gears. Would this not jolt the engine back to 4000rpm and cause issues??
if you want a launch interface get the gizzmo other wise forget it... its (bee-r) crude and evil if not setup properly.
buy the BEE-r if you like to make pointless noise, and break shit.
Thanks guys,
I'm not actually after a launch interface, and I already have the Bee-R limiter... I just couldn't understand how you could run a microswitch on the clutch in the following situation:
Rev1 = 7000rpm
Rev2 = 4000rpm
Current revs 6500rpm, depress clutch, engine attempts to ign cut back to 4000rpm, just think it would be quite a large jolt just for the potential to flat shift..
I have the Bee-R installed because of all the skidpan and motorkhana days coming up and I hate fuel cut...
Yes i can enable to launch controll setting on the power fc for RB25 and RB26. The ECU does support it but its not configurable with Datalogit.
How it works is that it limits the revs to whatever RPM you want it set to untill it reaches a speed of what you want it set to.
I think its a fuel cut launch controll as well :thumbsup:
I might have a play with it.
I think its a fuel cut launch controll as well :P
that is wicked!
If you get it working I would be happy to work out some deal with you so that i can have it enabled on mine! :thumbsup:
    • Johnny is sad now... Because you didn't get Bosch Motorsport ABS.
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
