Looking at buying a new garret turbo for my rb20.
Ive been search for last 2 days on specs for these 2 turbos.
GCG will do the 2871R with a skyline T3 rear housing.
How much effort is it to fit a 3071R, has anyone got one of these with .63 A/R and a 2.75" inlet.
If anyone can point me in the direction of a thread covering the variations of these turbos that would be great thanks.
See Nabil's thread on forced Induction http://www.skylinesaustralia.com/forums/in...=145752&hl=.
Also see Slide's prices on the trader section on SAU, good prices and http://www.skylinesaustralia.com/forums/in...howtopic=131709
Yep GT2871R series turbos use the high performance GT28 turbine with Garretts 71.1mm GT35 series compressors in 48 or 52 or 56 trim .
There are variations in both turbines and compressors in the GT3071R/GT2835 series cartridges/turbos . Don't be confused by HKS terminology - the 28 in 2835 does NOT mean it uses a GT28 turbine , they ALL use a cropped GT30 turbine in 84 or 90 trim .
The turbine takes one of three forms , cropped or 56.6mm OD in 84 or 90 trim . Unmolested in 60mm 84 trim . The real GT3071R uses the 60mm 84T turbine .
Compressors are same deal as the GT2871 or 71.1mm 48/52/56T .
Same old same old , drama is always getting a T3 flanged exhaust housing to suit the chosen turbocharger .
Three options with the GT2871R (or any GT28 series turbo with same turbine) .
1) Rat up the .64 A/R HKS housing from 2530/2540/2535 or GT-RS .
2) Reprofile one of the Nissan/Hitachi RB20/25/VG30 housings .
3) GCG's recent custom housing .
With "GT3071R's" there are some traps . Firstly some are made with the cropped GT30 turbine which would be sort of ok if the exhaust housing was GT30 based ie like HKS's T3 flanged ones . Sadly Garrett and HKS like to sell the things with bored out and butchered T28 flanged GT28 housings which don't work . Garrett call them "GT3071R-WG" and they are dogs . HKS also did it with GT2835's aimed at SR20/CA18's which have T28 flanged exhaust manifolds - note I mean the integral waste gated ones . HKS also have T28 flanged GT30 turbine housings that DO work just no integral waste gate .
IMO the ones worth using are the real GT3071R cartridge number 700177-5023 and one or two of the HKS custom combinations of the cropped GT30 turbine with the 52 or 48 trim compressor . The HKS option is expensive and may not get you the exhaust housing you want . The real Garrett 3071R can now be had with Garretts own GT30 integral waste gate exhaust housing so its reasonably easy , I would use the smaller .63 A/R housing if you do this .
RB20's have small ~ 330cc cylinders so not a mountain of torque at low/med revs . A bit of boost early on helps but if the compressor is a healthy one and steps are not taken to minimise it they surge badly once they get going . The old fix was to use larger A/R turbine housings but then you lose the bottom end torque . HKS gets around it by fitting port shrouded compressor housings ie to their RB specific GT-RS and possibly their RB type GT2530 which may have been called GT2530KAI . Some firms can do a ported shroud by machining the large boss type TO4B compressor housing like GT2860RS's and many GT2871R turbos come std with . Something like this or the RB type HKS GT-RS (GT2871R 52T with HKS housings) would probably be nice on a street RB20DET . Or if you know someone running the ball bearing Hi Flow get them to take you for a spin , you may like it .
Cheers A .
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
