um no i dont have one really that i could lend you but you can just go buy one make sure it has a warranty then if you swap it over and the prob is still there just take it back and say its faulty.im not 100% sure if they can be electroncally tested maybe someone on here knows.but yeah good suggestion is to advance it first and see how you go.
thanks for the info, i think i will try a differnet cas and see if that fixes anything. its worth a try i guess.
  • Replies 45
Posted Images
just a quick question, is it that the car is just plain slow, or is it a start/stop/start/stop type of thing?
No its a start then stop thing. The tubo spools as normal but car serverley hisitates, almost undrivable, cant really take it over 2.5-3k
I dropped it into F.I.S.T. performance as they are local and one of the few workshops open today and the only works shop who would take the car with such little notice.
So fingers crossed i get it sorted and i will report back as to what the problem is.
I have found other posts with similar issues to what i experience but when they get it fixed no body reports how they fixed it :(
Hey guys! got it back from FIST performace, guys there where great very knowledgable.
Okay when it came in on the dyno it made 128rwhp.
List of things fixed.
- I had a busted fuel pressure regulator
- MY airflow meter was no good!! i tried 2 sensors previously and also resoldered one but that didnt solve it.
- Timming, The cas seems to be in a very advanced position, Tuner said for some reason this car needed a lot of timing to do anything. I know the car has had a rebuild from previous owner with pistons but thats all i know.
- boost 11psi
When it was sorted on the dyno it ran 270.9 RWHP or 202.1 RWKW.
Air fuel ratio varied from about 11.8 - 10. Tuner said it still runs very rich.
I have a SAFC neo comming so that should help things in that respect.
Does any one know why my car needs more timing than a normal r33?
And what do you guys think about the power figures? any thoughts?
Total aftermaket mods to this stage are,
- pod filter
- metal intake pipe
- walbro fuel pump
- FMIC delta fin style. piping is hybrid copy.
- dual stage turbo xs boost controller(low 9psi- high 11psi)
- GFB BOV switchable plumb back type.
Thanks for every ones ideas on this thread!
Are the Cams different?
Thats good power for 11psi.
It was more than just one thing wrong, no wonder you couldnt get it right.
I pretty happy :P
As far as i know the cams are stock, The previous owner claimed a rebuild and showed me some photocopy of a trade reciept for acl pistons but npothing else so i am doubtful if it is legit.
The Timing belt was changed a few months ago.
"R33S2" are u asking if the cams are differnet because the CAS seems to be in the far advanced position? im curious as to why this is too?
Yeah two things wrong makes it hard to diagnose, expecially when i ruled out airflow meter my trying two and resoldering one.
Cheers
I pretty happy :P
Cheers
it can mean a few things, aftermarket cams, timing belt fitted right??, qoute me if i'm wrong guys.
Check your Timing Belt Tensioner, they are a spring loaded mechanism from what i remember, if its broken timing belt could be far from taught and the reason you need to run spastic timing, if the covers are on your tuner wouldnt have seen shit.
Good to hear you got it sorted :P
Not surprised the AFM was a problem, but it's quite rare for the stock fuel pressure reg to die in my (limited) experience. I suppose they're not getting any younger so things are going to start playing up.
Dunno about the timing thing - maybe the cams have been timed, ie one or both have been advanced or retarded, so compared to where the CAS normally sits it might be a degree or two out. I'm probably completely off the mark but that's my best guess :rofl:
Your not wrong about these cars not getting any younger,
If it is the timing belt pretensioners woulnd they maybe casue the belt to slip? some times at idle there is a wirring sort of squiggle noise from the cas area. The cas bearings are fine so it may be a pretentioner?
Edited by tmc_2
maybe the timing belt has jumped a tooth on 1 of the cams. how many k's on the car (in total, not just since rebuild). it may be that when the engine was rebuilt they didn't replace the timing belt, and it is due to be changed.
my mates 180sx that is having similar problems is overdue for its second timing belt (its done over 200,000ks). we have to keep the timing fully advanced to get it to perform. we tried jumping a tooth with the cas and it was way too advanced. we think the timing belt may have jumped a tooth.
total kays are 125thou , timming belt done at 117thou and rebuild i am gussing some where between 90 to 110thou.
SO u htink its worth getting then to check the timming belt is its alligned correctly?
Will it be fine to just leave alone?
thans Mad082
so u've still got the stock ecu? prolly best to get a power fc (or other) and get it tuned properly. i.e lean it out a bit, then you'll also be able to pull some timing out. it'll go harder, and it wont chew as much fuel >_<
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
