  • Replies 55
Posted Images
I'm quite interested in the Secret tweak you speak of Andy, and will be in contact in the near future about it mate.
What I'm more interested in at the moment, is whether the R34 GT T PFC will plug straight into an S1 ECU harness, and if it will actually run the S1 non NEO motor successfully.
https://www.sau.com.au/forums/topic/149695-power-fc/page/3/#findComment-2812163
Sure it will "run" the RB25DET. But it won't have any VVT, simply put;
1. The PFC expects (talks to) an infinitely variable drive for the inlet camshaft
2. The RB25DET (non Neo) has only an on/off switch on its VVT
3. So they won't talk to each other
So my guess is everything else will work, but not the VVT. Anything that doesn't work should be easily fixed, but not the VVT. For example the ATTESSA outputs from the ECU.
Notwithstanding the auto transmission issue of course.
:huh: cheers :P
https://www.sau.com.au/forums/topic/149695-power-fc/page/3/#findComment-2814461
SK, is there any way to "trick" the R34 OFC to run in an on-off mode? Like maybe set the parameters to fully-switched on or fully-switched off where appropriate, instead of having values running up and down on a scale?
Oh, and should I disconnect the battery before unplugging and removing my ECU?
https://www.sau.com.au/forums/topic/149695-power-fc/page/3/#findComment-2814735
On the non-neo engines (on/off vvt control) it's as simple as making a small circuit that turns the vvt off at a certain rpm.
I've seen it done when the R32 ECU's were reprogrammed to be used on the R33's. The R32 ECU's didn't have any vvt control so (as I said above) a small circuit was made to switch it.
Run the car up on a dyno with the vvt off, then do another run with it on, where the two point cross is where you want it to switch. If I remember right, the vvt is ON at low rpm and then turn off at around 4500rpm ?
So I'm guessing that if the vvt issue is the only 'work around' then it'll be a piece of cake to get the R34 Gtt PFC to work on the Stagea's (if you can put up with the hard shifts).
Sorta makes me wanna buy another Stagea :) sniff sniff....
https://www.sau.com.au/forums/topic/149695-power-fc/page/3/#findComment-2814766
I wonder if Power FC's have an auxillary output, most aftermarket ECU's do. So when you reach a certain rev range it switches on eg: nitrous or a water spray. I imagine this could be used for the VVT.
I'm interested in this as I'm in the process of doing a manual conversion, so the auto wont be an issue for me.
https://www.sau.com.au/forums/topic/149695-power-fc/page/3/#findComment-2815152
bejeesus
Myself me and I, have been in a R33 with 300rwkw, automatic with MV Autos shift kit, and with Power FC.
It DOES bloody work
The gears shifted fine, whether it was city traffic driving, or spirited hills driving.
Power FC + MV Auto vale body DOES WORK for the automatics.
https://www.sau.com.au/forums/topic/149695-power-fc/page/3/#findComment-2816242
  • 3 weeks later...
Hi guys I am reading all about you guys discussing if a R34 GTT APEXi power fc and be used on a Series 1 Stagea but this model of power fc has been discontinued so it is not possible to buy it now:-( And if any of you guys know of where to get 1 or have 1 yourself to sell then could you please PM me as I am looking for 1 for my R34 GTT powered R32 GTST. And also does anyone know if a R33 RB25DET power fc can be used on a R34 RB25DET NEO?? Thanks
Edited by drifta69
https://www.sau.com.au/forums/topic/149695-power-fc/page/3/#findComment-2861650
Ok, I've found out that the VVT on the R33 and R34 are basically the same ON/OFF, the R34 has just been improved to give a smoother transition. So this should work ok.
The other problems are that the R34 has a boost pressure sensor and the R33 doesn't, also the R34 has some sort of throttle motor on the throttle body.
The power FC could be easily fooled into thinking these were connected, but would this affect the running of the engine if it didn't get the correct signals?
https://www.sau.com.au/forums/topic/149695-power-fc/page/3/#findComment-2897822
  • 4 weeks later...
  • 8 months later...
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
