  • Replies 54
DIRECTIONS
I won't be at dinner, so y'all have to find your own way there. This is the location and map of Lucky's.
http://directory.ourbrisbane.com/directory...ngs/211758.html
As you are travelling along Brunswick Street (heading the opposite direction to New Farm (ie. as if you are going from New Farm park towards the train station), turn left into Martin Street (you will see the Coffee Club / IGA / Eagle Boys in the same complex (Central Brunswick)). Once on Martin Street, you can pretty much see Lucky's straight away on your left. There is a parking lot right next to Lucky's, which has 270 car parks, and is for use by anyone utilising any of the facilities in Central Brunswick.
Anna
i'm gonna have to bail sorry. money is not permitting this week. i either go tonight or friday's cruise. i picked fridays. sorry guys, will let you know if things change.
After reading all the posts, this is what I worked out:
Troy
Jason is a maybe
Lee is a maybe (he wanted to start at 8pm)
Jarrad is a maybe (starts new job today so not entirely sure if he can come)
Dave (zippo0_) is in if other people are going
Dave (Rhino) is not able to make it
Sorry but Marc & I cannot make it either
PS. normally the dinners are not like this, but it is just after christmas and quite a few people have come down sick...so hopefully there''ll be more people next week :nyaanyaa:
aww :P tis a very quiet one this week, could be because of everyones alledged new years resolutions of saving money?
i know that will hold me back a little but ill still come if ive ot the chance
:D just not tonight......otherwise id love to keep the loners company :nyaanyaa:
does this leave like 4 maybes???
Just a suggestion, can we have next weeks on northside? I know of a The land of goat sphincter rings resturant near tombul (dont remember actual suburb) there is normally live belly dancers.
just a suggestion
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
