  • Replies 54
DIRECTIONS
I won't be at dinner, so y'all have to find your own way there. This is the location and map of Lucky's.
http://directory.ourbrisbane.com/directory...ngs/211758.html
As you are travelling along Brunswick Street (heading the opposite direction to New Farm (ie. as if you are going from New Farm park towards the train station), turn left into Martin Street (you will see the Coffee Club / IGA / Eagle Boys in the same complex (Central Brunswick)). Once on Martin Street, you can pretty much see Lucky's straight away on your left. There is a parking lot right next to Lucky's, which has 270 car parks, and is for use by anyone utilising any of the facilities in Central Brunswick.
Anna
i'm gonna have to bail sorry. money is not permitting this week. i either go tonight or friday's cruise. i picked fridays. sorry guys, will let you know if things change.
After reading all the posts, this is what I worked out:
Troy
Jason is a maybe
Lee is a maybe (he wanted to start at 8pm)
Jarrad is a maybe (starts new job today so not entirely sure if he can come)
Dave (zippo0_) is in if other people are going
Dave (Rhino) is not able to make it
Sorry but Marc & I cannot make it either
PS. normally the dinners are not like this, but it is just after christmas and quite a few people have come down sick...so hopefully there''ll be more people next week :nyaanyaa:
aww :P tis a very quiet one this week, could be because of everyones alledged new years resolutions of saving money?
i know that will hold me back a little but ill still come if ive ot the chance
:D just not tonight......otherwise id love to keep the loners company :nyaanyaa:
does this leave like 4 maybes???
Just a suggestion, can we have next weeks on northside? I know of a The land of goat sphincter rings resturant near tombul (dont remember actual suburb) there is normally live belly dancers.
just a suggestion
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
