  • Replies 54
DIRECTIONS
I won't be at dinner, so y'all have to find your own way there. This is the location and map of Lucky's.
http://directory.ourbrisbane.com/directory...ngs/211758.html
As you are travelling along Brunswick Street (heading the opposite direction to New Farm (ie. as if you are going from New Farm park towards the train station), turn left into Martin Street (you will see the Coffee Club / IGA / Eagle Boys in the same complex (Central Brunswick)). Once on Martin Street, you can pretty much see Lucky's straight away on your left. There is a parking lot right next to Lucky's, which has 270 car parks, and is for use by anyone utilising any of the facilities in Central Brunswick.
Anna
i'm gonna have to bail sorry. money is not permitting this week. i either go tonight or friday's cruise. i picked fridays. sorry guys, will let you know if things change.
After reading all the posts, this is what I worked out:
Troy
Jason is a maybe
Lee is a maybe (he wanted to start at 8pm)
Jarrad is a maybe (starts new job today so not entirely sure if he can come)
Dave (zippo0_) is in if other people are going
Dave (Rhino) is not able to make it
Sorry but Marc & I cannot make it either
PS. normally the dinners are not like this, but it is just after christmas and quite a few people have come down sick...so hopefully there''ll be more people next week :nyaanyaa:
aww :P tis a very quiet one this week, could be because of everyones alledged new years resolutions of saving money?
i know that will hold me back a little but ill still come if ive ot the chance
:D just not tonight......otherwise id love to keep the loners company :nyaanyaa:
does this leave like 4 maybes???
Just a suggestion, can we have next weeks on northside? I know of a The land of goat sphincter rings resturant near tombul (dont remember actual suburb) there is normally live belly dancers.
just a suggestion
    • Why are people so insistent on making dirty water?!
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
