  • Replies 56
Posted Images
These are sooooooooooooo coool age. Cand you do a write up for these puppies in a nutshell? Or is it a little too complex for us photoshop novices??
that's right AGE... its about time you stepped out of the VIC section and did some tutes for the graphic design section.
https://www.sau.com.au/forums/topic/149791-carz/#findComment-2794545
Ummmm, it's alot easier to do them tha it is to do a DIY on how to do them. ;)
You need some big pics of the actual pixar cars themselves, and cut and paste the best fitting eyes and mouth, then free transform/distort(ctrl T) them to fit. Then it's just a case of matching the color of the donor car with the cut and pasted parts.... thats the hard part, and black cars are the hardest, surprisingly yellow was very easy :)
I use lumination/replace color/brightness/contrast and matching color tools on photoshop. Also alot of history/eraser and eye dropper/paint brush tools as well. It a bit of work to match the color, but playing around with different tools, you'll sort it out. Best thing to do is start with a white or light colored car and play around with different tools. Ctrl Z is your friend :P
Here's some more.
https://www.sau.com.au/forums/topic/149791-carz/#findComment-2794585
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
