well basically as the title says i've lost my locknut and i'm in the need for some new tires soon (good thing its not a daily driver) Its a lock nut i've never seen before so i'm not really expecting anyone to have one.
My mate has a ute with mags and lock nuts and he got tires the other day not even thinking about the locknut and he went to pick the car up and the tires were changed, it wasn't til i mentioned about how they got the wheels off that he realised he didn't even have a locknut (never got it when he bought the ute)
So do tire places have spare locknuts or what?
Any suggestions of what to do would be much appreciated!
(i've already tried putting a socket on it!)
i had this same prob when i bought my car.no lock nut key with it.and the bloke changed numbers or something and couldnt get a hold of him.. they where light as hell alloy one.tried socked but didnt work
so i took it to tyre shop and they used a even smaller socket(19mm) i think and got it of..charged me 20 bucks
that happen to me when bought my car. took it to bridgestone and they had a box of lock nuts. eventually found 1 that was close then hammered it on and tuned it. got em off but have to be careful not to grind it away otherwise wheels will neen do be cut off.
Take it to a wheel/tyre shop and they'll get em off for ya. Most places have a special set of sockets called locknut breakers designed to get locknuts off. If you want, bring it to my work and I'll get em off for ya, they're a piece of piss, provided they are an external nut sorthing. Not the ones with the pattern on the inside.
I lost my key, using the locknut breakers, I had all of the locknuts off in 5mins :P
I had special lock nuts (with a rotating outer piece) on my S15 and the key got mangled - Bridgestone actualy welded/fused the spinning part to the main part of the nut then we smashed a socket over them - came off eventually
salad where are u i will get u to take my left rear off the rotor its jammed like a muther ***********
Tyrepower Campbelltown
If you need the help, PM me and I'll give you my number and then you can come in and we'll get the thing off :laugh:
the amount of frustration i went thru when a company i took my car to told me they had to hammer a socket onto my lock nuts to get em off so that they could change the wheels.
nice way to destroy a set of anodized blue Rays wheel nuts.
i didnt have then key for my wheel nuts, and my mechanic got them off and the nuts were still useable, then shortly after the key was found lol...
theres a few lock nut manufacturers around adelaide, u can go see them and see if any of their keys fit...i tried that but mine was some wierd one...
Ive got a set of lock nut removers at work that shouldn't really destroy your lock nuts. So if you want come down to north tce tyres and ask for jarrod and i;ll do it. Phone number 83624417
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
