The next Winton Fun Day is scheduled for Sunday January 28th 2007.
The Fun Day is a "come and try" day and is designed to allow the average motorist access to a real race track under controlled conditions.
Cost:
Is $25 per driver and $25 per passenger
Programme:
Normally be there by 8.00 for scrutineering, but this can take some time.
Drivers Briefing at around 9.00 - 9.30
Driver only on track for 30 minutes sighting laps, then
Driver with passenger for 30 minutes, then
Driver only on track for 30 minutes, then
Driver only on track for 30 minutes, and so on all day until about 4.30
Requirements:
Bring your car, an Australian Standard Approved helmet, the helmet can be either open or closed face, fire proof clothes that cover you from neck to ankle to wrist (cotton or wool clothes are good). Runners are not the preferred footwear, Blundstones boots (or similar) or any leather type shoe is preferable
Make sure your car has no oil/coolant leaks, fitted seat belts, battery is secure, wheels nuts are tights, no loose items in the car or boot.
The Car does not have to be registered, but has to road/race worthy. Tyres need to be in good nick, tread depth is not normally a problem unless wire is poking out.
There are normally no checks done of lights except for brake lights except if it is an overcast, rainy day, then there may be checks for lights as well as wipers.
Tow bar tongues and bull bars must be removed.
You do not need to have a race licence, club licence or indeed a car licence abut you must be over 16 to drive or be a passenger.
And very importantly, bring a smart, alert attitude, coz there is some very fast cars out there, whilst it is not a race meeting, some people bring race cars and we push them hard to behave appropriately around first timers.
Food and drinks are available through a canteen.
https://www.sau.com.au/forums/topic/149944-winton-fun-day-a-come-and-try-day/
I'm in Mt Beauty that weekend so I might stay on an extra night and have a go. I have a mate coming too. Can we share the driving in one car?
Russ
Yep, but you both need to pay and get a wrist band.
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
