  • Replies 46
Tried an ignition module tonight, no change. Noticed that when I dropped the bonnet that the car stuttered, thought it was alarm based fiddled, no change. Fiddled with AFM wires and got varying reactions depending on which wires I hold and if I earth them or not. Noted some elec tape on the AFM plug wires, peeled it back, looks good enough but something has been done there before. Pulled the airbox out, cleaned the AFM's and their plugs and tried to wrap the wires separately to ensure no earthing, put it all back together, same problem is evident. idle has also at 1200rpm too, this was evident before I did my stuff tonight. If I try to rev above say 2500 it misfires at all temps which suggested coils/plugs (new plugs are arriving tomorrow anyway so they'll go in and I'll inspect each coil individually while I'm there (they're splitfires and the car has 35,000k's so if they're genuine the coils can't be too old but in reality they could be up to ten years old - didn't think they were prone to failure though?) I pulled coil and plug number one and both appeared fine for reference. The loom that the AFM plug runs into looks a little worse for wear in my opinion too.
What's everyone's thoughts? TPS? AFM's? The car is booked in to an autoelec on Thursday but if I can sort it myself and save myself another day of driving the 1.6L Corolla I'd love to =\
Cheers
It sounds like something to do with the AFM's to me, when you unplugg the AFM on a gtst the car wont drive past 2500rpm-3000rpm and will coff and splutter which sounds like similar symptoms as what your car is having.
I had the same issue with my 32gtr..
Was an afm. It would drive fine then turn to sh*t. Wouldnt rev, wouldn't do anything.
And it was very random when it happened. Till i Spat it one night on a trip home (about 150km to go) an smacked the afms...
It fixed the problem temporarily, so i shook them till it came good.
Changed them one at a time with my friends afms and fixed the problem.
Ended up changing to Rb20 ones for greater hp capability (I have a power fc tho..)
Hope this helps
cms
Nope not as yet, didn't bother last night as it seemed AFM related and more so related to the plug/wiring than the actual AFM itself.
CMS: This isn't random it happens every time I drive the car after 10mins or so. It also did it last night straight away after starting, wouldn't rev past 2500.
That's plenty for me, cheers.
I'll let everyone know what the AutoElec says tomorrow fingers crossed it's just a wiring/earthing issue doesn't need parts as well as labour =D
good luck with her mate... it will come good
Had exactle the same prob with my car... Changed the AFM's and the car was fine...
My car wouldnt rev over 2500 and it used to stall when stopping at lights if i didnt have my foot on the accelerator...
You can recondition your AFM's by resoldering them and there is a DIY in the tutorials section of the forum...
Should be fine if you change them (or one) resolder them...
Good luck.
Thanks heaps for the info, I'll have a look at the tutorial but it seems more wiring than actual AFM related to me given I could hold the wires and earth myself to get various results.
I think we're on the right track though and hopefully the AutoElec is worth his hourly fee =D
Just got the call then and the AutoElec is confident the AFM is at fault as it's giving error codes which confirms my suspicions. I've having him give the wiring into the AFM a once over but otherwise will be trying the AFM repair tutorial listed on here tonight and seeing how we go (also sourcing another AFM just incase it can't be repaired) Received my IRITOP's today also so they can go in as well.
Let you all know how I go later.
Pulled the AFM tonight and sure enough, dry solder on the AFM plug pins, followed the tutorial on repairing the AFM, car drives like new again. After I was happy that it was fixed we also put in some new IRITOP's, so all running sweet.
Thanks everyone for all your help!
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
