I will have S15 Front seats that i will have for sale in about a week or 2.... just wanted to know if anyone would be interested... it practically new, will be coming off the last yellow Spec R S15 sold brand new in NSW :D i've traved 12000-ishkw in them...
will try get a pic once there off the car... i've been offered $500 but would like $600 atleast...
L8Rz
They should they will come with rails not sure which ones yet cause i have 2 rails a brand new one for the EK civic and the standrad ones... you "may" have to cutomise a bracket though to fit the standard bolt patterns....
L8Rz
Guest Joel
I'm that mate!
I'd be quite interested in the seats (thats if you haven't sold them already). My drivers seat is bent or something. If you could send me some pics of the seats when you get a chance i would really appreciate it. I've never sat in s15 seats before but i'd assume they would be a bit more supportive than the standerd R31 family car seats!!
My email is:
[email protected]
Thanks Heaps
Joel
Originally posted by croat
Do they fit in a r33 gtst? can u get backs also?
they wont fit, you'll need slight modifications to the outside rear part of the rail (i think).
Christian
when i had my 180 i had R32 seats put in, the modification to the rail was done by a mates mate with a welder and took about 1 hr in total (and that includes pulling the seats out and putting the new ones in). it would be a similar time frame for vice versa, the outside rear rail would need to come forward (i think) about 3/4 of an inch.
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
