im plannin on gettin my exhaust housing hpc coated just wondering where is good place to get it done in sydney/illawarra area and whats the rough prices?
also i have my exhaust manifold heat wrapped, would it be better to coat that as well? ( its a 6boost manifold, not stainless)
any help appreciated
cheers...ben.
https://www.sau.com.au/forums/topic/150523-hpc-coating/
Previous manifold and and compressor cover were done by GCG...no idea on price as it was done by previous owner.
Now have a manifold for a V6 being done by Competition Coatings in Guildford picking up end of the week. About $250.
https://www.sau.com.au/forums/topic/150523-hpc-coating/#findComment-2802933
I would think that as long as you are keeping the wrap on the manifold then no need to coat it as well but it certainly wont hurt.
my mate has just opened a shop and does ceramic coating, inside and out, he did my xspower manifold and rear turbo housing,
he does a really good job, he is starting to do coloured coatings as well,
i can ask him on prices for each part to be coated, he is on the central coast.
cheers
Jeremy
https://www.sau.com.au/forums/topic/150523-hpc-coating/#findComment-2804516
I would stick to coating the outside of the exhaust cover and manifold... As much as they guarantee the material will stick to the metal, I have no doubt over time that it will delaminate from the part.
I don't like the idea of little pieces of ceramic coating heading through my exhaust wheel...
https://www.sau.com.au/forums/topic/150523-hpc-coating/#findComment-2805090
true that Ronin...
thanks DVSR32 that would be appreciated
has anyone heard or dealt with Competition Coatings in Sydney?
ben...
i use and recommend competition coatings
the chrome-look on the pipes and compressor covers below is ceramic coating not chrome
the high temp black can be seen in the second pic
https://www.sau.com.au/forums/topic/150523-hpc-coating/#findComment-2807560
I have used Competition Coatings and High Performance Coatings. HPC is better, though its quite a lot more expensive. Things liek manifold and exhaust housings/dump pipes will be past their best after about 12-18 months depending on the amount of driving you do (Satin black) Nothing lasts forever....
https://www.sau.com.au/forums/topic/150523-hpc-coating/#findComment-2807764
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
