Hey all, I just ordered these ($270, still need to be told delivery cost):
http://www.perfectrun.com.au/performance%2...ppbrakeline.htm
Are APP any good? I was contemplating the Endless ones, but for $350ish plus delivery I went with the APP brand. I might get the clutch line as well when I get the funds for the clutch itself as well....
There was 2 group buys but I decided against them (although 1 ended in August):
http://www.skylinesaustralia.com/forums/in...howtopic=127127 - $309
http://www.skylinesaustralia.com/forums/in...howtopic=128648 - $360
https://www.sau.com.au/forums/topic/150627-braided-lines/
I use the nismo lines on my GTR and they are very high quality. If anything though the APP ones are just as good or better. They are not specifically ADR approved, but I would suggest their design and manufacture do meet ADRs, they just have never sought or gained 'approval' (if in fact such a thing exists).
https://www.sau.com.au/forums/topic/150627-braided-lines/#findComment-2805595
I thought www.braidedlines.com.au had the strangle-hold on ADR approved lines?!?!
Just a vague memory.
The difference between an ADR approved braided line and not is a little rubber sleeve that goes inbetween the hose and the connector when its crushed. It'll have a compliance number on it... That's the only difference, line and fittings are exactly the same!
Any of your local ABS service centres can make ADR approved lines! :cool:
https://www.sau.com.au/forums/topic/150627-braided-lines/#findComment-2816909
jetpilot1986
Thats not correct because the goodridge hoses are ADR approved and they don't have the rubber sleeve
https://www.sau.com.au/forums/topic/150627-braided-lines/#findComment-2816931
I quickly searched for tutorials but theres none on changing brake lines. Is it easy or hard to do? I have to replace my front wheel barrings soon so I can do both.
Tom they are not hard to do. The hardest part of the process is getting hold of a brake bleeder etc to do the job.....bit messy too :cool:
What Mr keets says it correct...tech they make your car illegal and unroadworthy but I am yet to hear of a claim or otherwise (roadworthy etc) being knocked back because of them.
https://www.sau.com.au/forums/topic/150627-braided-lines/#findComment-2816940
Tom they are not hard to do. The hardest part of the process is getting hold of a brake bleeder etc to do the job.....bit messy too :O
I really do need to bleed the brakes again I think (or get a new brake booster). I can hold my foot at a certain point in the brake and I get a constant squealing sound :P
Do Nissan sell the brake bleeders or are they a supercheap item?
https://www.sau.com.au/forums/topic/150627-braided-lines/#findComment-2817300
Are you sure the squealing isn't coming from the actual brake pads/rotors? It is a common thing on skylines and I'm sure a search here would bring a heap of threads about it. Does the pedal feel soft...ie you brake at a point and to maintain the same braking force the brake pedal drops more?
Brake bleeders are basically a hand pump (although you can get elec ones)....you disconnect the brake line at the caliper, attach the bleeder to the system and pump the fluid out. You also use it once you are finished to get all the air out the system. Most tool places have them....
https://www.sau.com.au/forums/topic/150627-braided-lines/#findComment-2817325
No, its defaintely a booster or master cylinder seal because if I get it in the right spot it just keeps on and on squealing ..... ( :P ). It happens everytime I stop. Pedal is soft also but thats what ABS does anyway isn't it?!
I bled the brakes through the ABS bleed holes last time so maybe that was the problem.....
https://www.sau.com.au/forums/topic/150627-braided-lines/#findComment-2817594
  • 1 year later...
hi guys im currently in the middle of a brake upgrade on my r33 gtst, im going to run rda slotted rotors on all 4 corners as with QFM pads, whilst i was swapping out the front rotors today i notice that on one side the hard line that runs into the caliper from the bracket where the hard line turns to a rubber line is broken.
can u get these from any decent brake store or do they need to come from nissan?, i wouldnt mind upgrading to braided lines but does this replace the hard lines alltogether by just running straight to the caliper?
all help much apprietiated
cheers nick
https://www.sau.com.au/forums/topic/150627-braided-lines/#findComment-4130814
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
