Hi ppls,
Just a little heads up.
I've been hunting around for front end bushes and stumbled upon Nolathanes Front End Vehicle Enhancement Bush kit for the R32's.
The best price I have tracked down is $345 + Postage. I am waiting for them to be delivered via TNT Road express as I type, tomorrow I'm off to grab myself a cheap $150 12tonne press. I've always wanted a hydraulic press. :)
Back on topic... The kit I have coming to me is to suit the R32 GTST.
It contains:
Front Adjustable Upper Control Arm Bushes
Front Lower Control Arm Bushes
Front Adjustable Caster Rod Bushes
and.... When you fill out a form within the package Nolathane send you front end sway bar bushes.
Its almost too good to be true for $345 + postage (~$18). I've seen them go elsewhere for $400 and some places $500 for the same kit!
PM me if you want to know where I got mine from; however, until I receive mine there's no guarantee's. :)
I've attached a couple pics of the kit and whats in it. Note the blue marks.
Nolathane also do a bush kit to suit the R32 GTR and R33 GTST.
I'll report back once the bushes are in to let you lot all know if NVH increases as Nolathane bushes some years ago 'used' to be quite hard *from experience in a previous car*.
Nolathane do however claim
Nolathane is no longer hard and is now designed for normal street use as opposed to harder motor sport suspension settings
These changes allow Nolathane parts to provide performance enhancement without compromising noise, vibration or harshness (N.V.H.).
Did you re grease them every so often as you are supposed to? They look dry.
Torqued up correctly? Not just a yep that feels tight enough?
Just trying to get an idea of how/why they failed. Maybe 4yrs with the type of driving and amount of kays is about right????? I have NFI when it comes to bushes. :)
I used to have my VS Commo 5ltr 5speed bushes greased every 20-30k otherwise the slight squeek would jack me off. They were whiteline bushes but. There was one squeek turning in to my street as it went over a slight dip as I was turning at low speed that I couldn't get rid of. Then it went and ripped the sway bar riser out of the strut so in went whitelines riser to lower control arm kit that really firmed up the car nicely.
Can't wait!!! :(
Regarding the installation of bushes.
INSTALLATION PROCEDURES
* All suspension parts must be clean and free of paint, rust, grease and previous rubber deposits before fitting Nolathane components.
* Mounting pins, eyes and shoulders must offer no pitting, bending or distortion prior to fitting Nolathane components. where suspension parts show signs of deterioration or damage, they must be either replaced or repaired to manufacturer's specifications.
* Use lubricant supplied in kit. Grease all bush surfaces which are designed to pivot (i.e. internal bores and flange faces) . Do not grease outside surface of shackle bushes. Additional grease is available. Part number CVG10 (10 X 100g sachets)
* After Nolathane components have been fitted, vehicle must be at normal ride height (i.e. sitting on wheels unladen) BEFORE final tightening/torquing of location bolts, nuts and shackles is carried out.
* Before installing in vehicle, crush must be checked. Nolathane bushes have been designed to suit standard applications. Should vehicle be equipped with aftermarket suspension packages, size of bush must be checked for correct crush and outside diameter. All flanged bushes must offer 0.5-1 mm crush on each shoulder.
Can't wait!!! :(
Hope you have a cool temp with the castor bushes. if they aren't already broken the bushes are silica filled and oftern require an oxy to heat them up and burn them to get them out. When i do them at work i do them hanging up against a wall coz sometime they explode and hot silica hurts on the skin.
I have heard the caster bushes are a pain the arse to remove.
Both of mine started leaking around a year or so ago and have finally stopped leaking but make loud clunking noises. :S
So they are well and truly stuffed.
So given mine have already broken I should be ok yes?
Have you ever tried a hole saw on the end of a drill to help break them?
Thats how I done mine on my 33,
Once I cut the centre out, the outer pressed out very easy.
Edited by woolls
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
