Hi all, been calling Magman for the last week and a half to no avail....so does anyone know of any place either around blacktown or north shore that can weld up a crack on my rim? and that are actually open at the moment?
morton & may.
Don't have a ph #; they are in the book
Did a sterling job of a wheel that some freak had run down a gutter for in my estimate 20m or so.
Liverpool, NSW (might be called "wetherill park").
SW
Circle Track Wheels - Seven Hills
I just finished recoing a set of Super Advan II and I used them
Oooo, seven hills eh??? might be even better....I'll have to check them both out
I used Circle Track Wheels many many many years ago to fix a wheel on the Corolla. It would have been almost as cheap to buy a new wheel, but they'd just stopped producing the wheels I had, and finding one in the correct size was proving to be a right royal pain in the proverbial.
Then again, the damage to the wheel was fairly bad, and he did a good job.
Did I mention it was many years ago?
on old pitwater rd right?
did they give you a quote? I was going to go to magman but brookvale is alot closer.
the lady said all the guys are getting back to work on monday.......she said pricec range from $50 to $200, but looking at the crack, I'd probably wouldn't pay more than $100 for welding a small 2cm crack. So, I'm gonna go get it have a looked at first and get an official quote.
..........and yes, its on pittwater rd
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
