U'r lucky this is SAU and I'm not an admin here :)
I meant that people have replaced seals and then the car has done a Turbo shortly after.
which seals are we talking bout here? gaskets or turbo bearing seals?
btw pulling the front and rear off turbos are easy n wont stuff anything up.. if u start pulling the cartridge apart thats when ull have troubles
https://www.sau.com.au/forums/topic/151313-my-gtr/page/2/#findComment-2816651
Kushil - My Series II only had POD (enclosed, cold air feed and heat shielding foam) Turbo back exhaust and the factory dual stage boost bypassed so it would run 7psi all the time. At a guess, the car would've made 140-145rwkw's? It had Bilstien Shocks, King Springs, 265 rubber (rears 235 front) and a strut brace so it was fun to drive having come from an NA FWD Celica. The R makes my Series II feel like a stock NA silvia. The power and handling is not comparable. I friend of mine who drives a fairly modded 185awkw WRX explained that he didn't want to race me on the strip or track after going for a ride in it.
I was under the impression that moving into a GTR would just be a heavier, slightly better handling and more powerful Skyline but the difference between the two cars is much bigger than that. Drive one and you'll understand better, good luck on your purchase!
NB: To be fair, the R has more mods than my last car by the way.
Bugger.......ya...i got the same sort of mods in my GTST...no cold air shilelding though....and still on factory boost...probably a bit slower than you car.......
thankx for the info..
NB: To be fair, the R has more mods than my last car by the way. I am preety sure it has ???....
https://www.sau.com.au/forums/topic/151313-my-gtr/page/2/#findComment-2816676
I have always seen the 33's as a 'not rare enough for me' type car, maybe its just GTST's. But when I see the GTR's up close and in Midnight Purple I start to like them more and more.
But counting all the 32GTR's in Australia now I'm not one to talk :O ..... :P
https://www.sau.com.au/forums/topic/151313-my-gtr/page/2/#findComment-2817281
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
