I had the squealing noise at start up occasionally and read the thread on fixing it.
Unfortunately I can't see any of the photos attached in the thread, but there appears to be a missing nut on the adjustor bracket on my carpost-33161-1168559832.jpg. Where the long adjustor bolt threads into the block, poking out the front is a bolt that looks like it needs a nut (see attached photo). Nissan couldn't tell me whether a nut is meant to go there or not
There definately isn't a nut needed. I think your bolt is through the wrong way to be honest, the block is threaded from memory and the bolt when tightened should lock the assembly in place against the bracket. As it is now it can potentially flap about.
The pic is not very clear so i cant tell if you have the bolt that holds the block on . As BHdave said the block is threded and is bolted on the alternator with another bolt M8 from memory, you undo this a little then turn the long ajusting bolt until you have the correct tension and tighten the other bolt .
Agreed agreed.
The long bolt does not need a nut. It is locked into place by another bolt that runs perpendicular to the one pictured. Undo that locking bolt first, then the long one in the picture will turn without much resistance.
Oh I see what people are saying about the bolt being backwards. I think they're referring to the locking bolt. You can see the end of it poking out the front. I guess now this is the one you were talking about? It's threaded in that block where the head of the bolt is. (towards the rear)
I can't remember which way round it is supposed to be, but if it's backwards, then it won't be doing any locking whatsoever. I'll check mine next time I go downstairs for a smoko.
On every RB I've ever worked on that block is not threaded other than for the long adjustor bolt, but is clearance drilled and it's actually the mating lug on the alternator that is threaded (ie the part where you can see the bolt sticking out toward the bottom of that photo). So the lock bolt (which is what it's for - securing the adjuster mechanism) passes through that block, then the long adjuster bracket - which has a long, slotted hole - and finally screws into the threaded lug on the alternator. The idea is that the bolt clamps the block and the alternator to the adjustment bracket, which itself is attached to the block at the waterpump.
Looking at that photo I suspect your problem could be that the bolt is too long. The standard bolt would only stick out from the alternator lug by a few mm at most. It's not standard and it's possible that there isn't enough thread, which means the bolt isn't able to be tightened sufficiently before running out of thread. This would mean that it would _appear_ that the bolt was tight when it actually wasn't and that might explain your squeels. Either that or some idiot has stripped the thread in the alternator lug and slipped in a longer bolt to fix the problem, in which case there should also be a nut on that bolt (and the fact that there isn't one would also explain the squeels, etc).
There you go! The bolt is in the correct way. And as SteveL said, I can also see that my locking bolt doesn't stick out anywhere near that far.
Edited by RANDY
    • I was 99% sure the standard one is long enough to get there, you might just have to change the throttle orientation. If not, I remember someone having used an r31 cable instead, but that is probably harder to find than r33 by now...
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
