One of my exhaust manifold studs has snapped off in the head and I'm wondering if it will be alright to just leave it like that. Or would it cause a leak?
It was already snapped before I took the manifold off and there was no sign of leaking. But I'm now putting a highmount on and there will be fair bit more weight involved.
Any help would be much appreciated.
https://www.sau.com.au/forums/topic/151542-snapped-manifold-stud/
I don't know if you already do this but just a suggestion, I always use wd40 when taking off exhaust studs, let it soak in for about 30 mins then hit it again before you take them off.
I snapped a few previously before I started doing this, seem to have a higher success rate now.
yeah it get fixed. find a mobile thread repair guy.
if you try and do it yourself, and snap an easy out. it will end up costing double to get it proffessionally taken out
HAH! I snapped an easy out in one of my exh mani studs. I was able to grind the snapped off portion out of the stud using a dremel with a tungsten carbide bit. It ate through the hardened steel of the easy out like butter. Here is a link to the exact bit I used...
http://www.dremel.com/en-us/attachments-an...240&I=66310
Hope this helps someone out there =]
when i was taking mine out i was using wd40, id start turning them out and as soon as they tighten u go back in spray some more, then go back at it untill its out all the way.
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
    • It's TWO steering wheels actually. 😛 one for each hand They are wheels, and they steer!
